Hosting other services on SoftetherVPN server machine
CyprusSocialite
Post by CyprusSocialite » Tue Feb 25, 2025 8:03 pm
Here is my current setup:
  • Machine connected to internet via `enp14s0` interface
  • SoftEther virtual hub (SecureNAT disabled) bridged to `tap_softether` interface created in VPN Server Manager, and further configured by systemd-networkd:
    [Match]
    Name=tap_softether
    [Network]
    Address=192.168.100.1
  • dnsmasq running with the following configuration:
    bind-interfaces
    interface=tap_softether
    listen-address=::,0.0.0.0
    dhcp-range=192.168.100.11,192.168.100.250,255.255.255.0,12h
    dhcp-option=3,192.168.100.254
This works and I can connect to the VPN successfully, and dnsmasq assigns the client an IP as expected.
My goal is to host other services (web server, etc.) on the same machine where SoftEther VPN server is running, and have them listen on the `tap_softether` interface like dnsmasq seems to do.
This does not work, and when connected to the VPN I cannot even telnet anything on the server (via 192.168.100.1).
Moreover, I cannot figure out how dnsmasq is listening to the connections. I have tried stopping it and using netcat and socat to listen on port 53 (both tcp and udp), but I never get anything.
Please advise!
Re: Hosting other services on SoftetherVPN server machine
Post by solo » Tue Feb 25, 2025 11:39 pm
CyprusSocialite
Post by CyprusSocialite » Wed Feb 26, 2025 9:39 pm
"Bridge not working as expected"
I am not bridging to the physical ethernet interface, however - only to the tap interface, and it seems that dnsmasq is able to listen on it somehow...
Post by solo » Thu Feb 27, 2025 1:44 am
For a test disable iptables/firewall and try again.
CyprusSocialite
Post by CyprusSocialite » Thu Feb 27, 2025 10:24 am
I am using nftables and I have tried the following:
systemctl stop nftables
systemctl stop dnsmasq
nc -l 0 53
*connect to VPN from another device*
Server log has
Trying to request an IP address from the DHCP server.
Acquiring an IP address from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
But there is no output from nc. Same with `nc -lu 0 53`.
Post by solo » Thu Feb 27, 2025 1:02 pm
So you had disabled the DHCP server for some inexplicable reason, started listening on DNS port, and then wonder why netcat shows nothing and "Acquiring an IP address from the DHCP server failed".
It's hopeless, ask on a Linux forum. Nothing to do with SoftEther.
CyprusSocialite
Post by CyprusSocialite » Thu Feb 27, 2025 10:59 pm
Yes, my apologies, I meant to listen on the DHCP port 67 instead. Indeed this works, and in fact it looks like UDP works in general: I can `nc -lu 0 1234` or any other port, and then `nc -u 192.168.100.1 1234` from the client to get the expected output.
However, it seems that TCP does not work. So `nc -l 0 1234` / `nc 192.168.100.1 1234` (without -u) do not produce any output.
Perhaps SoftEther is filtering the TCP packets somehow?
My client is connecting via L2TP by the way - in case this is relevant.
CyprusSocialite
Post by CyprusSocialite » Sun Mar 02, 2025 3:00 pm
It seems the issue was caused by incorrect routing of outbound packets (my client was never receiving SYN-ACK).
Fixed by running:
ip rule add from 192.168.100.1 lookup main
ip route add 192.168.100.0/24 dev tap_softether
Gonna try and incorporate this into the systemd-networkd config
