I was using softether without issues for years, until a couple of days ago. Now, the dynamic DNS function does not work and in the Assigned Dynamic hostname field I get "None". I tried installing the server in different computers, deactivated the firewall, and even use a mobile network. None of this seems to help. Can this be a problem with the softether servers in Japan? For instance, the URL https://www.softether-download.com/ does not work. The same for https://www.softether-download.com/?product=softether.
Any help is appreciated.
Thanks!
RM
is the Softether service up and running?
michelena
Re: is the Softether service up and running?
This is what I see in the Dynamic DNS Function screen. It was working fine until a couple of days ago.
Any idea how to solve this?
The JP websites and services work for me. From your SE server PC post as code the output of:
tracert -d get-my-ip.ddns.softether-network.net
ping get-my-ip.ddns.softether-network.net
ping get-my-ip.ddns.uxcom.jp
