Multiple DHCP Subnets
Wurstsalat
Post by Wurstsalat » Mon Mar 03, 2025 12:57 pm
Hi there,
anyone has an idea if this is archiveable with softether.
- i want to have one VPN Gateway
- i want to have multiple dhcp subnets controlled (for example) bei different user groups (authorized by radius server)
So firewall after the vpn gateway can filter based on the client ip ranges
Impossible to configure or is there a way?
Kind regards
Re: Multiple DHCP Subnets
Post by solo » Mon Mar 03, 2025 11:45 pm
Bridge the VPN and preset clients with static IPs in any subnet you wish ;-)
Wurstsalat
Post by Wurstsalat » Wed Mar 05, 2025 7:44 pm
a solution....still in my first thoughts about it, seems horrible to implement when we speak in a scaling of up to ~800.
But thanks for a possible solution, still dont know if i try to implement :)
