Please provide the records of connections made to my computer.
CrazzyDog
I would like to check the logs of connections made to my computer on January 28, 2025.
Re: Please provide the records of connections made to my computer.
"C:\Program Files\SoftEther VPN Client\packet_log\VPNGATE"
CrazzyDog
CrazzyDog
It seems that my IP is involved in a crime.
It appears that IP sharing was enabled, and a crime was committed using my IP, and an investigation is currently underway.
I know the exact date (25.01.28) and need the access logs for the IP on that date.
Since the program has been uninstalled, there is no way to verify this now. Please help.
The uninstall process does not delete logs.
If you had deleted them manually, try a data recovery/undelete tool.
If the tool is unsuccessful, ask your ISP for the logs.
