Regarding the encryption algorithm settings of SoftEther VPN Server
LeeHS
About encryption and network in SoftEther VPN Server. There is an encryption algorithm setting inside. But no matter what you set, TLS_AES_256_GCM_SHA384 will be automatically selected when SoftEther VPN Client connects. Is this a BUG or a setting error?
Re: Regarding the encryption algorithm settings of SoftEther VPN Server
viewtopic.php?f=7&t=65167&p=88791#p95036Edit the config file in the server, and look for this value:
bool Tls_Disable1_3 false
Change it to the following value:
bool Tls_Disable1_3 true
LeeHS
Thanks for your help!solo wrote: ↑Mon Mar 24, 2025 5:11 amviewtopic.php?f=7&t=65167&p=88791#p95036Edit the config file in the server, and look for this value:
