I have two SoftEther servers in Europe: one in the Netherlands and one in Germany. I want to connect these two European servers to the SoftEther server in Iran using a cascade connection. What should I do?
Specifically, I want users to connect to Germany using the address de.domain.com and to the Netherlands using nl.domain.com, but the SoftEther server’s IP in Iran should be behind these domains. I hope I’ve made my point clear.
I’ve created two users in the "Manage Users" section, and in the cascade settings on the Iran server, I set up a connection for each European server. However, the problem is that both addresses, nl.domain.com and de.domain.com, are not differentiating and directing to their respective servers; they both show the same IP. What should I do?
NL Server ===> Iran Server====> users with nl.domain.com Connect to Netherlands
DE Server ===> Iran Server====> users with de.domain.com Connect to Germany
The problem is that users connect to a server randomly, and their connections are not separated or differentiated.
cascade 3 server
Re: cascade 3 server
Create two hubs with separate cascades.
BrandonOrndorff
Creating two separate virtual hubs and properly configuring the Cascade Connection seems like a very reasonable approach. I’ve been facing the same issue where users randomly connect without differentiating between the Netherlands and Germany servers. I’ll try implementing this method to see if it resolves the problem.
BrandonOrndorff and AlvaroHopson viewtopic.php?f=7&t=69598#p103311
Both from the same IP and posting chatbot-produced fluff for later edit to insert spam links.
FYI, edits are disabled on this forum, so you're wasting your time.
UPDATE
AlvaroHopson is already gone, could not edit it out and simply added a new post with spam links.
UPDATE
