The latest version can't create taskbar system tray icon
devv
Post by devv » Sat May 31, 2025 3:30 pm
I tried a few PCs running Windows 10 enterprise,most of them can't create taskbar system tray icon when install the latest version of Softether client.Any help please? Thanks~
Re: The latest version can't create taskbar system tray icon
Post by solo » Sun Jun 01, 2025 2:42 am
Yes it can and it is a trivially simple "fix".
