Howto create vpn tor android 15 without app? Help.
https://www.vpngate.net/en/howto_l2tp.aspx#android
"VPN on Android step by step guide (Using L2TP/IPsec VPN)" <-- old, incomprehensible. there are no such settings, no profile saving, no connection (hangs endlessly).
Howto vpn android 15 without app?
zarah56
Re: Howto vpn android 15 without app?
On Android 15, set up a VPN without an app:
Settings → Network & internet → VPN → Add VPN
Enter Name, Type (L2TP/IPSec or IKEv2), Server, Username, Password, Pre-shared Key
Save → Connect
Use IKEv2 for stability; ensure all credentials are correct.
Save → Connect
