Hell, dear users of SoftEther.
I've seen this problem all the time I was using SoftEther.
So, for example, we have 2 JP servers with the same ping in meni (1ms).
But, when I try first server on speedtest (by ookla) it shows me the real ping - 200ms
but then I try the second server - it shows me 40ms ping
why the ping is so incorrect 😭😭😭
Incorrect Ping In SoftEther
Wolfdmitrich
Re: Incorrect Ping In SoftEther
It is perfectly correct for a direct JP VPN Gate ping to a JP Google server.
Now, your 200ms indirect ping to JP means that you are somewhere between EU and JP - Russia maybe?
Wolfdmitrich
Thank you for your answer! But is there any way to show ping that will be for me? Like any plug-ins?
It'll be what you see in VPN Gate + You-to-that-Gate. For example: on a PC from CLI type "ping public-vpn-187.opengw.net" before connecting to this VPN; on Andr/iPh get a "ping" app.
