GLOBE (ISP) is actively throtteling VPN by 90% in Philippines,
does anyone know how to bypass this ?
Kind Regards
Ludwig
GLOBE VPN throtteling in Philippines
Ludwig1911
Re: GLOBE VPN throtteling in Philippines
Further to my original post
here are the screenshots with and without VPN
Ludwig1911
WITHOUT VPN
Ludwig1911
THIS IS THE VPN SERVER I WAS USING
So server #192 has Cumulative transfers of 617Mbps on 298 sessions.
Consider yourself lucky with ~30Mbps which is an excellent result for such a busy server. It has nothing to do with GLOBE (ISP).
Ludwig1911
You are wrong, GLOBE HAS acknowleged they are throttling,...
I tested the same setup from Singapore and got much better results (70%)
Sepp
Sepp
Let's see...
This is what the server statistically offers regardless of any ISP's policy.
617/298=2Mbps
