Hello, today I discovered that no VPN connection is working in the built-in VPN management utility in Windows 10. I took the connection parameters from this site - http://14.132.27.53:17922/en/
Are all users experiencing the same problem?
VPN is not working
Re: VPN is not working
Is this related to the Windows update?
Possibly. No problem in my W10 on SSTP to public-vpn-90.opengw.net
Microsoft Windows [Version 10.0.17763.5329]
(c) 2018 Microsoft Corporation. All rights reserved.
PPP adapter VPN Gate:
Description . . . . . . . . . . . : VPN Gate
Physical Address. . . . . . . . . :
IPv4 Address. . . . . . . . . . . : 10.236.2.138(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 0.0.0.0
DNS Servers . . . . . . . . . . . : 10.236.254.254
8.8.8.8
NetBIOS over Tcpip. . . . . . . . : Disabled
Tracing route to one.one.one.one [1.1.1.1]
over a maximum of 30 hops:
1 224 ms 279 ms 259 ms public-nat-out.vpngate.open.ad.jp [10.236.254.254]
2 586 ms 220 ms 228 ms gw2.vpngate.v4.open.ad.jp [219.100.37.253]
3 588 ms 344 ms 329 ms igp1.green.v4.open.ad.jp [202.222.12.190]
4 233 ms 579 ms 566 ms bgp3.openospf1.v4.open.ad.jp [202.222.12.33]
5 290 ms 319 ms 221 ms 150.99.184.33
6 600 ms 313 ms 338 ms 150.99.10.187
7 * 582 ms * 210.171.224.134
8 501 ms 707 ms 319 ms 103.22.201.25
9 366 ms 228 ms 572 ms one.one.one.one [1.1.1.1]
Trace complete.
On the W11 laptop, I also cannot connect on SSTP to public-vpn-90.opengw.net. It should be noted that my computer and laptop are connected to the same router. At the same time, I can connect to some VPN servers on my computer via OpenVPN. However, my laptop is connected to only one Thai VPN server: the server name is vpn464614923.opengw.net:1867, the protocol is SSTP, the rest is standard. But my laptop doesn't connect to any other VPN servers anymore.
UDP: However, if I turn on OpenVPN on my computer and then connect to the VPN server using the built-in Windows 10 tool, the connection will be successfully established.
