The client takes a very long time to connect. Sometimes immediately. Sometimes after 10 minutes.
Another PC is next to it on the table - it connects immediately.
WIN10.
I noticed this feature
in the field Virtual Hub Name the name in the drop-down list is unavailable.
it is available on other PCs and there are no connection problems.
Is it related to the virtual adapter?
Error 1 is almost always
warwar32
Re: Error 1 is almost always
No, in the FW allow TCP/UDP in/out for both vpncmgr.exe and vpnclient.exe.
