Android Connection
clo69
Android Connection
Post by clo69 » Wed Oct 15, 2025 4:07 am
I'm trying to set up my Android device to connect to my VPN The instructions say to use the L2TP/IPSec PSK setting. I don't have that setting; I only have IKEv2/IPSec PSK., Is it possible with this setting?
Matsuzaka_Satou
Re: Android Connection
Post by Matsuzaka_Satou » Mon Dec 22, 2025 8:26 am
I saw it was an old issue on github (see https://github.com/SoftEtherVPN/SoftEtherVPN/issues/13 ). Interestingly, even after one decade, this issue is still open. They suggested porting Openswan or StrongSwan to fix it.
But it's Android, for me, I wouldn't necessarily insist on using IKEv2; I'd look for a third-party SSTP client to solve the problem, such as Open-SSTP-Client(https://github.com/kittoku/Open-SSTP-Client)
Griffy
Post by Griffy » Mon Dec 22, 2025 6:04 pm
Ditto on the Open SSTP client for android. It notably more modern/secure than ipsec/l2tp type setups.
obfusgated
Post by obfusgated » Thu Jan 08, 2026 9:41 am
Here's another free app for Android that supports custom SoftEther SSL-VPN profiles https://play.google.com/store/apps/deta ... sgated.vpn
Griffy
Post by Griffy » Thu Jan 08, 2026 8:44 pm
Thanks for the heads-up on that. This might be a good compliment to the SE server custom build I'm working on right now.
