I have two VPN servers, one on-premises and one in the Cloud. I successfully integrated the Radius server with the on-premises VPN server, but when I tried to integrate it with the cloud VPN server, I got the following error: " Radius Server - This Feature is not supported on . Its hasn't implemeneted on Open Source version of SofteTHER VPN"
Note : I used the same installer for both servers
yon
Re: Radius Server - This Feature is not supported on . Its hasn't implemeneted on Open Source version of SofteTHER VPN
If it is a JP cloud contact PacketiX.
On non-JP cloud use official SE binary, not the "Open Source version".
https://ja.softether.org/3-spec/cureent_limitations
yon
Thx bro for feedback, it's ALI CLoud bro
flexadmin
If you still need more info, you can ask google for region lock by key word "SiIsEnterpriseFunctionsRestrictedOnOpenSource"
