Certification CA and users account expiration
GiovanniG
Post by GiovanniG » Fri Nov 28, 2025 8:58 pm
Hi mates, I've experience building SSTP server with Mikrotik, and I would test also this solution.
I would know if there is a guide how to generate a CA certificate (using Let's encrypt?) by the GUI and eventually how to scedule an automatic renew..
I wouls also now if there is a way to set a date/time limt for the user, when expired the account can't be used more. Possible by the GUI?
Thank you for your kind support
GiovanniG
Re: Certification CA and users account expiration
Post by GiovanniG » Mon Dec 01, 2025 9:40 am
May somebody give me info about that, thank you!
Post by solo » Mon Dec 01, 2025 10:28 am
GUI > Manage VPN Server > Encryption and Network > Export > X509
- then on a client import it into "Trusted Root Certification Authorities"
GiovanniG
Post by GiovanniG » Wed Dec 03, 2025 11:11 am
thank you, I did this in past with mikrotik but Win10 is really capricious and on one PC it works, on 2 others not. It loves to check it onlne, so I switched to Let's encrypt. There ia a way to use let's encrypt with Softether?
Thanks
Post by solo » Wed Dec 03, 2025 8:31 pm
