SecureNAT VPN for LAN gaming - Connection issues
deb_user
Post by deb_user » Fri Nov 28, 2025 10:45 pm
Hi everyone!
Bit of a back story:
I'm running SoftEther VPN Server on a Debian 12 VM (Proxmox) for LAN gaming since about two years without any larger problems. All LAN games worked perfectly fine so far, except of one specific game: CoD - WaW Zombies / Coop.
The weird part:
I first tried this game back in Mai of 2024 and it worked perfectly fine. Now over a year later my friend and I wanted to play it again and... it does not work anymore. To be more precise the player who want's to join is able to see the Host in the server browser but as soon as he wants to join the message "This game session is no longer available" appears.
What changed:
Not that much honestly. Back then we've used SoftEther VPN Server v4.43. Both clients used SoftEther VPN Client v4.43. Since then I've updated the server and also client to v4.44. Other than that I've always installed / updated the packages on the server (Debian 12) and we both also always applied the various Windows updates. Back then my friend was on Windows 11, I was on Windows 10. Now we both are on the most recent versions of Windows 11.
Server configuration:
- Enabled SecureNAT with Virtual DHCP (No Default Gaetway or DNS is set)
- Disabled Virtual NAT
- No Local Bridge configured
- No specific Security Policy set for both users (already tried setting unlimitted broadcasts with no success)
- All other settings are basically the default / disabled
What I've already tried:
- As mentioned above I've set unlimitted broadcasts on both users via Security Policy
- Checked that the Virtual VPN adapter metric is set to "1" on both client systems
- Disabled SSDP on both Windows Clients
- Set up another fresh VM and tried with v4.43 of the SoftEther VPN Server, also installed v4.43 of the SoftEther CPN Client Manager for both clients
- Just to be sure: I've tried this game / mode on two pcs on my local LAN which worked perfectly fine
I've tried really hard and searched the internet for days now but I can't find a solution. Oh btw: The settings on the SoftEther Client Manager are all on default as far as I know (haven't changed anything special in there).
I'm happy to provide all important settings / screenshots of the server and / or client configs if needed. Would appreciate any help :)
Re: SecureNAT VPN for LAN gaming - Connection issues
Post by solo » Sat Nov 29, 2025 3:33 am
Hi, this is an interesting case.
Disconnect one of them from the LAN and connect via a mobile/cell hotspot, while the other connects with SE LAN address. If it still works for you, we'll focus on your friend's PC next.
deb_user
Post by deb_user » Sat Nov 29, 2025 10:30 am
Thank you for your response. I've already tried that with no luck. The weird thing is that if I connect both LAN pc's with SE LAN address it's the same behavior, I can see the Host (no matter who creates it) but can't connect. This tells me that it has to be something on SE / the connection itself that is blocking, either Server or Client if I'm not completely wrong.
Post by solo » Sat Nov 29, 2025 10:58 am
You have not mentioned anything about the firewalls - disable both for a test.
deb_user
Post by deb_user » Sat Nov 29, 2025 11:32 am
Oh yes sorry I totally forgot to mention that. I already did, it was one of the first things I did on both client pc's. I'm also able to ping each other.
Post by solo » Sat Nov 29, 2025 12:17 pm
Would you be able to test it out on a Windows SE server? If you you don't have a spare PC/VM, simply install it on one of the SE client PCs and from it connect to localhost. The server's settings need to be identical to your Debian's. More info https://www.vpnusers.com/viewtopic.php?f=7&t=68129 and https://sites.google.com/view/softether-vpn-gaming
deb_user
Post by deb_user » Sat Nov 29, 2025 9:20 pm
Yes I was able to test according to your advice. I've set up Windows SE Server on a spare PC and imported my config from my Debian SE Server. The result sadly is exactly the same. No matter who is hosting the game, it's visible to all other VPN clients but no one is able to connect. I even tried adding a third VPN client on the Windows SE Server pc, but it's the same.
I also followed the specific steps on your provided links and changed some of the settings on my server according to them but also with no luck.
Post by solo » Sun Nov 30, 2025 1:20 am
As there is no server OS issue, client OS may be the reason for old LAN games' problems. Before we start dissecting Windows 11 in this context, can you...
- re-try it on Windows 10 from eg. a VM
- check other LAN games from your collection on Windows 11
- try CMR2 on Windows 11 (it's discussed in the above link)
CMR2 was fixed by disabling SSDP, which you have already done, but this game was never run on Windows 11 back then.
deb_user
Post by deb_user » Sun Nov 30, 2025 11:19 am
Alright I've got some news on this
Haven't done this yet but all the other suggestions you mentioned.
The ones I've tested work like a charm, no matter if they are from the 2000 era or newer ones. At least the ones I used to play back then.
Installed the most recent version of Collin McRae Rally 2.0 including the "SilentPatch" on both Win11 client PC's and set compatibility mode on cmr2.exe to WinXP-SP3 on both PC's. One client is on the same local network as the Debian SE Server runs, so I connected via LAN IP from SE Client, the other one is connected via mobile hotspot to simulate being "external". And it works flawlessly without doing anything special, both clients are able to host and join a game.
It was not necessary to disable it, SSDP service is still running on both Win11 PC's.
Post by solo » Sun Nov 30, 2025 12:42 pm
It would be necessary to disable SSDP when UPnP is offered from a router.
I'll check CoD-BO on my W11 PCs, not sure if 'zombie' co-op mode is there though. Also my W11s are heavily optimized for max efficiency and the test may be inconclusive. For example I could not reproduce the CMR2 problem on my setup because I never allow SSDP service. The issue was revealed when the OP provided MS Network Monitor's packet logs for examination. Here you can clearly see CMR2 'deviating' from the VPN net into LAN and consequently failing...
deb_user
Post by deb_user » Sun Nov 30, 2025 2:00 pm
UPnP is disable on my router (pfSense).
As far as I know there's no real LAN mode in CoD-BO, tho there's a zombie co-op mode.
As mentioned above I also wasn't facing the issue with SSDP on CMR2, it worked perfectly fine without disabling it. So I don't exactly know why others had this problem but it isn't there in my case.
I remember that I've read something that CoD-WaW zomboies / co-op mode uses SessionID's to connect, but I'm not 100% sure and idk if this makes any difference. Still strange that it worked last year and every other game I've tested works as well, including CMR2 which seems to have made problems on other ppls configurations.
How can I check which source goes to which destination as your screenshot shows?
Post by solo » Sun Nov 30, 2025 2:11 pm
  • install Microsoft Network Monitor 3.4 https://www.microsoft.com/en-us/downloa ... px?id=4865
  • reboot
  • run Microsoft Network Monitor
  • select all net interfaces/networks (if not selected already)
  • click on "new capture"
  • click "start"
  • run the game, start hosting and try to play with a guest
  • click "stop"
  • check the log
deb_user
Post by deb_user » Sun Nov 30, 2025 9:01 pm
  • reboot
  • click "start"
  • click "stop"
  • check the log
Thank you! I'll debug later and report back my findings asap.
Post by solo » Mon Dec 01, 2025 2:57 am
Great, while waiting for your net packets observations let's clarify the CMR2 on SSDP issue.
Well, re-read your post, can you see the contradiction? SSDP depends on UPnP, so disabling any of them makes CMR2 work and it's no wonder that "it worked perfectly fine" for you.
CoD-BO Zombies on LAN is not easy as it tries to contact a server on the internet first. I'll get CoD-WaW co-op soon.
deb_user
Post by deb_user » Mon Dec 01, 2025 1:12 pm
Aah yeah got it, sorry I phrased it a bit strangely. Tho one thing isn't clear to me: Why does the game in LAN mode depend on UPnP?
That's what I also found about playing CoD-BO Zombies on LAN. Alright that would be awesome if you could check it out by yourself and maybe there's something I'm just missing.
I do have the logs form Microsoft Network Monitor. This is the protocol when hosting a lobby and it looks exactly the same, no matter if I'm connected to the VPN (Subnet: 10.20.30.1) or just hosting in LAN (Subnet: 192.168.1.1). Looks like it does not bind to the correct IP, tho why I'm then able to see the host?
Post by solo » Mon Dec 01, 2025 11:49 pm
Hold on, why is dem-onw-are there? Haven't you applied the LAN Fixed patch?
deb_user
Post by deb_user » Tue Dec 02, 2025 6:44 am
That's a good question. Yes I have applied the LAN fix patch.
Post by solo » Tue Dec 02, 2025 10:43 am
Please make another test in this non-VPN, LAN-only mode but disconnect the internet from your router. Can you still play it normally?
If not, then for VPN play you need to enable DG/DNS and vNAT in SecureNAT (default settings). Microsoft Network Monitor says so :-)
deb_user
Post by deb_user » Tue Dec 02, 2025 7:42 pm
I can't just disconnect internet from my router because of my server, but I did add a fw rule on my pfSense to block all IPv4 and IPv6 traffic to go outside of the LAN for the two PC's. And I'm still able to play in LAN co-op, tho the game loads a lot longer trying to connect to a server. First it says: "Retrieving accounts information..." for about 10 seconds and then it says "Online Service Error - Can not connect to Online Service". I can click "Ok" and then I'm in the main menu of the game and can host and / or join a LAN session.
This is what the Microsoft Network Monitor has logged:
Post by solo » Tue Dec 02, 2025 11:48 pm
OK, keep blocking "Subnet: 192.168.1.1" and also block "Subnet: 10.20.30.1" then try it on VPN. Blocking with the exception of WAN VPN traffic of course. Alternatively check what happens when only IP of the URL we see in MS NM is blocked.
deb_user
Post by deb_user » Wed Dec 03, 2025 7:34 pm
Alright I've tried your suggestions:
  • Blocking my LAN subnet and also the VPN subnet didn't change much. The output of MS NM still looks kinda the same and connecting via VPN behaves the same - I'm able to see the game host but can't connect.
  • Blocking the IP of the dem... - URL leads to the loading / trying to connect to online services delay when starting the game. Also MS NM does not log anything about the CoD Lanfix exe this way.
    Post by solo » Wed Dec 03, 2025 8:16 pm
    I see. Apart from the patch, is it v1.7.1263, v1.6.1252 or something else?
    Also, to finalize all easy tests please "enable DG/DNS and vNAT in SecureNAT (default settings)" and try it on VPN.
    deb_user
    Post by deb_user » Thu Dec 04, 2025 7:28 am
    Yes it's updated to v1.7.1263 and then applied the LAN fix.
    I'll try that later when I'm back home. What should I put in as DG and DNS address there?
    Post by solo » Thu Dec 04, 2025 8:30 am
    The defaults...
    deb_user
    Post by deb_user » Fri Dec 05, 2025 10:02 am
    The defaults...
    Sorry for the late reply and thank you for the screenshot. This is what I got now:
    The behavior is still the same tho, the client is able to see the host but can't join.
    Post by solo » Sat Dec 06, 2025 1:27 pm
    This may be another case of "it works for me", lol.
    Let's sync our files first as I noticed various v1.7 versions.
    - CoDWaW LanFixed.exe CRC32=17C435B2 (guest) [CoDWaW LanFixed 1.7.rar]
    - CoDWaWmp.exe CRC32=92CDECF8 (host) [COD_WAW_PRIVATE_SERVER_PATCH_1.7.rar]
    Next, use an off-LAN VPN server for a test from http://www.packetix.net/en/vpn/ and set it up as follows...
    Your PCs will have this VPN routing...
    Active Routes:
              0.0.0.0          0.0.0.0     192.168.30.1    192.168.30.10      2
            127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
            127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
      127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
         130.158.6.70  255.255.255.255      192.168.8.1    192.168.8.115     25
        130.158.6.116  255.255.255.255      192.168.8.1    192.168.8.115     25
          192.168.8.0    255.255.255.0         On-link     192.168.8.115    281
          192.168.8.1  255.255.255.255         On-link     192.168.8.115    281
    The ping is horrible because of a huge distance to JP server but it's irrelevant for this test.
    Pinging 192.168.30.11 with 32 bytes of data:
    Reply from 192.168.30.11: bytes=32 time=1219ms TTL=128
    Reply from 192.168.30.11: bytes=32 time=479ms TTL=128
    Reply from 192.168.30.11: bytes=32 time=601ms TTL=128
    Reply from 192.168.30.11: bytes=32 time=502ms TTL=128
    MS NM logs similar traffic to yours but with endless "negotiating" due to the DG to nowhere. However the real VPN traffic is logged as "Unknown" on UDP.
    Everything just works in this configuration.
    (Please do not quote my entire post - there is a "Post Reply" button at the very bottom for a plain reply :-)
    deb_user
    Post by deb_user » Sat Dec 06, 2025 6:37 pm
    First, thank you very much for getting the game and trying out on your side.
    Okay now first things first:
    - CoDWaW LanFixed.exe CRC32 is exactly the same on my file. Tho I'm using it on both clients.
    - CoDWaWmp.exe - I don't use the private server patch file beacuse it's only used for the MP and not the Co-op / Zombies. Tho MP works perfectly fine for me.
    Now I've created a server / virtual hub as you suggested with the config you mentioned and connected both clients to it (Client 2 over my mobile phone hotspot so that both clients are truly separated).
    My entire IPv4 routing-table looks as follows:
    Aktive Routen:
         Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
            127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
            127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
      127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
         130.158.6.70  255.255.255.255      192.168.1.1     192.168.1.10     20
        130.158.6.106  255.255.255.255      192.168.1.1     192.168.1.10     20
          172.26.32.0    255.255.240.0   Auf Verbindung       172.26.32.1    271
          172.26.32.1  255.255.255.255   Auf Verbindung       172.26.32.1    271
        172.26.47.255  255.255.255.255   Auf Verbindung       172.26.32.1    271
          192.168.1.0    255.255.255.0   Auf Verbindung      192.168.1.10    276
         192.168.1.10  255.255.255.255   Auf Verbindung      192.168.1.10    276
        192.168.1.255  255.255.255.255   Auf Verbindung      192.168.1.10    276
         192.168.30.0    255.255.255.0   Auf Verbindung     192.168.30.10    257
        192.168.30.10  255.255.255.255   Auf Verbindung     192.168.30.10    257
       192.168.30.255  255.255.255.255   Auf Verbindung     192.168.30.10    257
            224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
            224.0.0.0        240.0.0.0   Auf Verbindung     192.168.30.10    257
            224.0.0.0        240.0.0.0   Auf Verbindung      192.168.1.10    276
            224.0.0.0        240.0.0.0   Auf Verbindung       172.26.32.1    271
      255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
      255.255.255.255  255.255.255.255   Auf Verbindung     192.168.30.10    257
      255.255.255.255  255.255.255.255   Auf Verbindung      192.168.1.10    276
      255.255.255.255  255.255.255.255   Auf Verbindung       172.26.32.1    271
    Ping also works (if the windows firewall is disabled on the destination client). And yes it's quite slow.
    Ping wird ausgeführt für 192.168.30.11 mit 32 Bytes Daten:
    Antwort von 192.168.30.11: Bytes=32 Zeit=667ms TTL=128
    Antwort von 192.168.30.11: Bytes=32 Zeit=600ms TTL=128
    Antwort von 192.168.30.11: Bytes=32 Zeit=731ms TTL=128
    Antwort von 192.168.30.11: Bytes=32 Zeit=654ms TTL=128
    First thing I've noticed was that both clients now take some time when the game has been started to show the main menu because they are trying to connect to online services (as already mentioned in a prior post).
    The behaviour is still the same in the end, no matter who creates a host in game, the other client is able to see it but can't connect to it. I've also disabled the Windows firewall on both clients just to be sure while testing.
    This is what I've got in the MNM for the CoDWaW LanFixed.exe
    And this is what I see under "unknown" (related to the VPN IP)
    I haven't configured anything special on the vpn server / hub, just created the hub and endable SecureNAT with the settings you've provided. Everything else is left at default.
    Do you have the just installe the latest Steam build and added the CoDWaW LanFixed.exe?
    Post by solo » Sun Dec 07, 2025 2:17 am
    NEIN! Only a guest-client needs it and when I try your approach I get your [non]results.
    Before you ask, I start a host with the original CoDWaW.exe CRC32=EADCA70A
    deb_user
    Post by deb_user » Sun Dec 07, 2025 3:58 pm
    You're right, only the clients (non-host) need the LanFix. Although in LAN it works even when the host uses the LanFix
    LAN only
    - Everyone uses the LanFix -> Works
    - Only clients uses the LanFix -> Works
    - Clients not using the LanFix -> Doesn't work, they get kicked out while loading
    Now I've already mentioned that the CRC32 hash on my LanFix matches with yours. But the CRC32 hash of the CoDWaW.exe does not match. Are you using the Retail version or the Steam one?
    By trying my approach and getting my [non]results do you mean when both host and client uses the LanFix you get the error with "Game session no longer availeble..." ?
    Did you change something on the security policy for the users?
    I've now tried on 3 different pc's where one is always connected to my mobile hotspot to have them completely separated. Just to be sure it definitely will not be a VPN issue, would it be possible to try with yourt test-VPN? Perhaps it's also a problem with the .exe file, tho it works on LAN so I don't think this is the case here.
    Post by solo » Mon Dec 08, 2025 7:45 am
    It's the retail version and with LanFix running on both PCs, a guest can not find game host at all, although I tried it once from one direction only. No change in the security policy but I changed Windows 11 to 7 because of game GUI glitches and crashes. On W11 it was almost unusable before any LAN or VPN connection attempt. As for VPN concerns, SE in this mode is L2 and everything simply has to work. Finally, before the next VPN test, delete C:\Users\...\AppData\Local\Activision\CoDWaW - or wherever your user profiles are saved.
    deb_user
    Post by deb_user » Mon Dec 08, 2025 10:36 am
    Alright, I'm also using the retail version and installed all updates up to 1.7. Strange that we have different CRC32 checksum on the CoDWaW.exe. And also strange that your guest can't find any game with LanFix running, finding the host game works for me no matter if I'm on LAN or VPN and LAN play works perfectly that way.
    Also strange because the game works without any issues on all 3 of my Win11 machines.
    That's what I also thought because every other game just works perfectly fine in VPN. I've already deleted that folder on all 3 machines but still no luck. And as I said in the beginning of this thread, it used to work before, tho every pc was on Win10 back then.
    So is it possible that this could be a very specific Win11 issue, where just this game has some issues playing over VPN but not in LAN? Another thing could be that it's a problem using a mobile hotspot on one client, tho other games work that way as well.
    Or is there anything saved in the Windows registry for this game that leads to this problem? I don't think it's my Router / FIrewall (pfSense) because the SE Server TCP port is open and clients are able to connect.
    Post by solo » Mon Dec 08, 2025 11:10 pm
    There is only one registry key used [HKLM\SOFTWARE\Activision\Call of Duty WAW] but it is essential for the game and not related to the problem. I'll double-check on the LanFix phenomenon but this time on other, more game-suitable PCs with W11-22H2 and a W10. Meanwhile let's revisit your firewalls. While you had disabled them before there are still so-called Network Filters which you can examine like this: run as admin "netsh wfp show filters", it will create a file in the current directory named "filters.xml" containing information on all of the currently active network filters. The file is too big and too private to share online and you need to check it yourself. Here are two examples of active net filters superseding MS firewall.
    			<filterKey>{de8bf15e-fff8-4b90-bacb-507fd9de72b7}</filterKey>
    			<displayData>
    				<name>simplewall</name>
    				<description>App\autoruns.exe</description>
    			</displayData>
    			<flags numItems="2">
    				<item>FWPM_FILTER_FLAG_PERSISTENT</item>
    				<item>FWPM_FILTER_FLAG_INDEXED</item>
    			</flags>
    ...and our own SoftEther's TunnelCrack protection entries...
    			<displayData>
    				<name>_SeVPNFW ACL 0005: tcp out new deny any4 * * 10.0.2.15</name>
    				<description/>
    			</displayData>
    			<displayData>
    				<name>_SeVPNFW ACL 0014: tcp out new deny any4 * * 192.168.0.1</name>
    				<description/>
    			</displayData>
     			<displayData>
    				<name>_SeVPNFW ACL 0012: icmp out all deny any4 * * 10.0.2.15</name>
    				<description/>
    			</displayData>
    			<displayData>
    				<name>_SeVPNFW ACL 0021: icmp out all deny any4 * * 192.168.0.1</name>
    				<description/>
    			</displayData>
    deb_user
    Post by deb_user » Wed Dec 10, 2025 8:16 pm
    Alright, there's indeed nothing interesting in the Registry there. That would be awesome if you could check if it also works on w11. Currently I'm in 25H2. I've also created the filters.xml with the help of your command, thanks for that, I didn't knew about wfp filters at all. So there's a lot about SoftEther within that file (it's huge tho). But I don't see anything with IP's or something like that. What would be important to watch out for?
    Post by solo » Sat Dec 13, 2025 2:45 pm
    Yes I get it on W11/W10 too. ForceBindIP should have fixed it but it is ineffective, a fascinating problem, stay tuned...
    deb_user
    Post by deb_user » Sat Dec 13, 2025 6:43 pm
    I'm so glad that you were able to reproduce the problem :-) Yes I also had no luck with ForceBindIP. It's just so strange. I've checked so many things that have changed since it worked back in Mai 2024 on Win10 clients and I just couldn't make it out. I'm not 100% sure anymore but it could be possible that one of my friends PC was running Win11 back then at that time. Slowly I'm guessing that something important changed in Win10 and Win11 since then.
    Post by solo » Tue Dec 16, 2025 3:46 am
    UPDATE
    An intro to the game's LAN interactions with LanFix.
    - game client broadcasts "getinfo xxx" packets on UDP 28960+ looking for a game host
    - game host responds with "infoResponse... hostaddr..."
    - game client replies on UDP to hostaddr:3074
    - game client and host begin to play on UDP port 3074
    The root of the problem is in the host's choice of advertised "hostaddr" when both VPN and LAN interfaces are available.
    On Windows 7 it chooses properly VPN's interface but on Windows 11 (and apparently latest W10) it chooses LAN's interface despite higher metric. It may be related to active/connected interface index order rather than metric alone.
    W7: netsh interface ipv4 show interfaces
    Idx     Met         MTU          State                Name
     28           1        1500  connected     VPN - VPN Client
     27          25        1500  connected     Wireless Network Connection 5
     23           5        1500  disconnected  Local Area Connection 4
    W11: netsh interface ipv4 show interfaces
     14          65        1500  connected     Wi-Fi
     11           5        1500  disconnected  Ethernet
    It seems that the game picks the highest-index connected interface, which on W7 is VPN but on W11 is LAN/WiFi. So, it plays perfectly on Windows 7 and fails on Windows 11. Note that only game hosts must use Windows 7 as any game client will then work just fine.
    While I investigate it further please check if using LanFix in dedicated server mode on W11 is plausible. This mode was meant for multiplayer of course but the "exe" does accept a command line with "+set net_ip x.x.x.x" and offers a management console. Also LanFix exe has embedded strings like "dedicated LAN server" and maybe overriding network interface choice with net_ip will work.
    deb_user
    Post by deb_user » Thu Dec 18, 2025 9:35 am
    Sorry for the late response, I was able to try it just now.
    That's some very interesting stuff you found out! That might explain why it worked perfectly well last year. Damn MS, why are you changing these kind of things...
    I browsed a bit reagrding this metric behavior and there are indeed some people facing a similar problem where chaning the metric doesn't do anything anymore, tho no one is complaining about gaming, more like networking stuff in general but it seems to be a real thing!
    I've played around with the console and the parameters as you suggested. First thing I noticed was that no matter what IP you set with the "net_ip" parameter directly on the shortcut of the LanFix, it always reads out the main connection IP at the beginning of the console output (where it prints out Hostname and IP-address).
    But setting a different IP from a different range by this "net_ip" parameter on just one client it seems to have some effect, the other client's can't see the host anymore. But also setting the IP on both clients as the correct (VPN) one's it's still the same issue -> host shows up in lobby but connection is not possible. The same applies to running the host in dedicated mode (console command "dedicated 1" for LAN server).
    The interesting part for me is how this game seems to select and bind the IP address, because other games work fine, even tho the metric thing within Windows10/11 seems to be the issue...
    Post by solo » Fri Dec 19, 2025 4:09 am
    This old game selects the highest interface index as a primary network. Back then, in Windows 7 era, one could do as follows.
    Click on Start > type "network connections' in the search box and then click on "View network connections"
    Then Click on Organize > Layout > Menu Bar
    From the menu bar click on Advanced > Advanced settings
    This will give the order in which the network connections are accessed.
    https://learn.microsoft.com/en-us/answe ... r-order-in
    A top item in the GUI dialog has the highest index - simple and effective but this option has disappeared in Windows 11.
    Now, here is Windows 11 fix you have been waiting for ;-)
    - on your game host PC add an extra vNIC in SE manager
    - assign it to your Packetix test hub
    - it will look similar to...
    - do not reboot :-)
    - start your VPN and the game (no need to change anything on a game client/guest PC)
    - my log...
    W11-22H2
    -- pre-fix status: netsh interface ipv4 show interfaces
      1          75  4294967295  connected     Loopback Pseudo-Interface 1
      8           1        1500  disconnected  VPN - VPN Client
     14          25        1500  disconnected  Wi-Fi
      9          25        1500  disconnected  Local Area Connection* 1
     15          65        1500  disconnected  Bluetooth Network Connection
    -- VPN2 added: netsh interface ipv4 show interfaces
     36           1        1500  disconnected  VPN2 - VPN Client
     16          25        1500  disconnected  Local Area Connection* 10
    -- after a reboot: netsh interface ipv4 show interfaces
     15          25        1500  disconnected  Wi-Fi
     12           1        1500  disconnected  VPN2 - VPN Client
     17          25        1500  disconnected  Local Area Connection* 10
     16          65        1500  disconnected  Bluetooth Network Connection
    As you can see VPN2 has the highest index and the LAN/VPN gaming connection issue is resolved... till the next reboot. Tell us how it goes on your network.
    deb_user
    Post by deb_user » Sat Dec 20, 2025 6:26 pm
    This is absolutely INSANE! Just tried it and it works on my own SE server as well, crazy! I can't thank you enough solo!!
    Two questions remain to me:
    - A year ago the metric sestting worked fine on Win10 and Win11, why the heck did MS change something important like that? I haven't found a way to make it persistant (registry for example).
    - It's also special, that tools like ForceBindIP have no effect. I wonder if a modified exe could solve that problem or if this is deeper backed into the game libraries?
    At least there's a way to get it to work again, thank you so much!
    Post by solo » Sat Jan 10, 2026 8:02 am
    ForceBindIP is obsolete and completely useless on Windows 10+ nowadays. Its clone called BindIP explicitly states "known bugs - Windows 8/10 support. We need to do a full filter which is immense PITA. Patching mode is unreliable too" https://github.com/katlogic/bindip
    But we have Windows 11 workaround #2 with permanent settings and only minor game preparation steps. Follow me...
    HOST PRESET (one-off)
    Install Microsoft Loopback Adapter (MLA) for Windows 11
    - as admin run: hdwwiz.exe
    - select "Install the hardware that I manually..."
    - select Network Adapters
    - select Microsoft > "Microsoft... Loopback Adapter"
    - reboot (!)
    set static IP on MLA: 192.168.30.2
    set static IP on VPN2: 192.168.30.3
    - VPN2 vNIC is now permanent
    - keep VPN(1) vNIC default with dynamic IP for other connections
    set to auto and start "Routing and Remote Access" service if not already started
    optionally create "Network Connections" desktop shortcut: ncpa.cpl
    HOST GAME SESSION
    disable your main Eth internet NIC or do not connect WiFi yet
    - if there is 2nd WiFi/Eth active, it has to be disabled or turned off too
    - all "Media disconnected" NICs are irrelevant (check with ipconfig /all)
    - a "Network Connections" shortcut would be convenient here
    run the game and start hosting it
    press Alt+Tab to see PC desktop
    enable your main internet NIC or connect WiFi
    start your VPN on VPN2 vNIC
    return to the game
    GUEST PRESET (one-off)
    connect VPN
    route -p add 192.168.30.2 mask 255.255.255.255 192.168.30.3
    disconnect VPN
    GUEST GAME SESSION
    just start your VPN and play the game
    DIAGNOSTICS
    a guest must be able to ping 192.168.30.2
    > #1 or #2?
    deb_user
    Post by deb_user » Sun Jan 11, 2026 12:22 pm
    Thank you very much solo for this detailed guide!
    I think for me (playing the game once a month at most) the solution #1 where I have to add a second vNIC within SE VPN Client Manager everytime I want to play is more than sufficient and also doesn't add too much complexity. When done playing I just remove the vNIC and I'm set for the next time I want to host a game.
    Huge thanks again, appreciate it a lot for helping debugging the issue and finding a solution that works!
    Let's hope MS re-thinks about their change and will add a feature to let the user set the priority or just fix the metric setting again.
