My suggestion to shadowrocket APP written in email
https://apps.apple.com/us/app/shadowrocket/id932747118
buginapp@gmail.com
Hello,shadowrocket developer,i have an advice that i want you , the developer of shadowrocket APP,to integrate the SoftEtherVPN & Microsoft MS-SSTP VPN protocol right within the shadowrocket APP,also i hope you can support all functions currently shadowrocket is using right now,especially the proxy over another server node function,what i means is that softether & MS-SSTP VPN protocol in some areas of the world might require a proxy sitting in front of the target VPN server in order successfully establish a connection.
I'm not saying that SoftEtherVPN & MS-SSTP protocol is totally blocked world-wide globally,but as you know that if i connect to SoftEther & MS-SSTP using a http proxy / socks proxy connect method another unnecessarily RTT+1 will added to the VPN connection in which called TTL.
And if your app can directly handles the RTT problem right within the connect / post / get stage,such concerns can solved.
There's already a fine-tuned SoftEtherVPN & MS-SSTP Client APP on app store,i hope you can read the source code from https://www.domosekai.com/ and integrate such functions into the shadowrocket APP
https://apps.apple.com/us/app/sstp-connect/id1543667909
SoftEtherVPN & MS-SSTP are very well-known VPN protocol in tsukuba university,it just functions as the website the developers cited.
If the developer of shadowrocket APP accepted my suggestion,it will be nice to the entire VPN industry
oscar
