Does this software bypass [Forbidden router/bridge operation policy] forced by softether ? https://www.nat32.com/
A VPN Server have forcefully turned [Forbidden router/bridge operation] ON = True , So we cannot use the target VPN Server as a regular IP Router.
But does this software bypass such limits solely out of softether control?
oscar
oscar
Re: Does this software bypass [Forbidden router/bridge operation policy] forced by softether ? https://www.nat32.com/
This answered my post https://www.vpnusers.com/viewtopic.php?f=15&t=69914 question too ,thank you.solo wrote: ↑Sat Dec 13, 2025 1:33 amYes, that or RRAS https://www.vpnusers.com/viewtopic.php?f=7&t=68422
I do successfully do this,however,in my research case,a Layer 2 device = Installed must equal true in a such case,if the following = true,this method is not possible
1.The operating system [OS] crashes after Layer 2 device is added
2.The operating system enforces security policies,which means Layer 2 device = Forcefully.disabled = True
3.The operating system along with the current subnet which the server sitting down to forbid to customize any routing table in any forms
So again,i do understand your answer,but the following is a must
1.Layer 2 device on local OS must compatable and do not causes crash at all
2.Local OS must fully allow installation of such device [Where a public computer do not]
3.The user role in the OS must allow the modification of routing table configs
By the way can softether exceptionally allow another advanced option [Override security policies enforced by the remote VPN Server in developer edition softether] ?
Developer are test/super users on their own,they don't need another person to help them config/modify such settings on him behalf
