How can I hide my FastAPI port behind a SoftEther VPN connection?
jnyum
Post by jnyum » Wed Dec 17, 2025 2:09 am
I’m currently running SoftEther VPN Server, FastAPI, and Streamlit on a Windows laptop in my home lab.
- FastAPI: running on port 8000
- Streamlit: running on port 8501
- Host laptop is connected to SoftEther VPN Server
- Internal laptop IP is fixed (static)
I want <HOST_IP>:8000 to be forwarded to Streamlit internally
(so accessing <HOST_IP>:8000 shows Streamlit)
Now I want to hide <HOST_IP>:8000 behind the VPN connection so that external users must connect through the SoftEther VPN before reaching FastAPI/Streamlit.
My question:
How should I configure SoftEther VPN Server so that:
Port 8000 (FastAPI → internally forwarded to Streamlit) is only reachable through the VPN tunnel, and
External clients connecting via the SoftEther VPN can access the service at <HOST_IP>:8000?
Any guidance on routing, L2/L3 bridging, or local bridge settings would be greatly appreciated.
Thank you :>
Re: How can I hide my FastAPI port behind a SoftEther VPN connection?
Post by solo » Wed Dec 17, 2025 2:40 am
