VPN traffic is detected and blocked when using SoftEther VPN (client + server)
assagai
Post by assagai » Wed Dec 24, 2025 7:49 pm
SoftEther VPN claims to support traffic obfuscation when both its client and server are used. However, many Russian websites still detect that a VPN is being used and block the connection. These same websites cannot be opened without a VPN at all.
What is confusing is this:
I can access these sites when connected to some public OpenVPN servers located in Russia.
But when I connect using my own SoftEther client and server, the traffic gets detected and blocked.
This suggests that the public OpenVPN servers somehow avoid detection, while SoftEther does not.
The Windows 7 client machine uses these settings:
Firefox Secure DNS: disabled (set to Off)
SoftEther VPN adapter: set to highest network priority
DNS tab option: “Register this connection’s addresses in DNS” is unchecked
DNS servers configured on the system:
Preferred: 1.1.1.1
Alternate: 1.0.0.1
DNS cache: cleared using ipconfig /flushdns
Leak test results: I tested the connection using services such as IP/DNS leak test sites. No IP or DNS leaks were detected.
Examples of sites affected by blocking:
mgts.ru
my.mosenergosbyt.ru
(Note: mosenergosbyt.ru loads normally, but my.mosenergosbyt.ru does not.)
I cannot find any SoftEther settings that allow me to fix this problem. Because my IT knowledge is limited, I would really appreciate explanations in plain, easy-to-understand language. Any suggestions are welcome.
Re: VPN traffic is detected and blocked when using SoftEther VPN (client + server)
Post by solo » Thu Dec 25, 2025 11:51 pm
This is bizarre as Russians usually complain about outgoing VPNs being blocked, eg. https://www.vpnusers.com/viewtopic.php?f=7&t=69366
Anyway, in your case it has nothing to do with SoftEther whatsoever. Look, mgts.ru connects fine via VPN Gate on SoftEther protocol, not OpenVPN.
Check if it works with JavaScript disabled and/or cleared cookies, but most likely your Russian SE server's IP is blocked.
assagai
Post by assagai » Mon Dec 29, 2025 5:49 pm
You are correct that most complaints from Russian users concern the blocking of outgoing VPN connections due to censorship. However, since the start of the war, the government has also begun restricting incoming connections to many local resources. Fewer people need external access to those services, which likely explains the scarcity of public complaints.
The SE server’s IP address is not blocked. I asked my friend, who provided his desktop to host the service, to test the same websites from his side. The sites open without any issues—both when accessed simultaneously with my connection and when tested at different times.
My suspicion that VPN traffic is being detected remains unchanged. I performed multiple connectivity tests. To rule out a browser-level issue, I also used low-level network diagnostics—specifically, ping and tracert to mgts.ru [IP: 195.178.108.240]. The same hardware and software stack was used throughout (SE client with VPN gateway plugin, browsers, and VPN gateway plugin).
The results are unusual, but the only consistent explanation I can find is that VPN-routed traffic is being identified and blocked at some layer of the network path.
For reference, the connection was configured using Azure. My friend was unable to set up port forwarding, which prevented further testing of externally reachable ports.
Baseline: VPN client off
Symptoms: the user of the machine where the SE server is installed can access the blocked sites. I cannot access these sites
ping mgts.ru
Pinging mgts.ru [195.178.108.240] with 32 bytes of data:
Request timed out.
Ping statistics for 195.178.108.240:
    Packets: Sent = 1, Received = 0, Lost = 1 (100% loss),
tracert mgts.ru
Tracing route to mgts.ru [195.178.108.240]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2     9 ms    10 ms     9 ms  d28-23-1-112.dim.wideopenwest.com [23.28.112.1]
  3     9 ms     9 ms     9 ms  10.52.148.34
  4    11 ms    11 ms    10 ms  76-73-165-194.knology.net [76.73.165.194]
  5    49 ms    47 ms    48 ms  23-28-210-80.static.evv.wideopenwest.com [23.28.210.80]
  6    45 ms    45 ms    47 ms  75.76.35.51
  7    34 ms    17 ms    18 ms  75.76.35.8
  8    18 ms    18 ms    17 ms  chi-b23-link.ip.twelve99.net [62.115.153.98]
  9     *        *        *     Request timed out.
 10    30 ms    33 ms    31 ms  ewr-bb2-link.ip.twelve99.net [62.115.132.134]
 11   109 ms   108 ms   109 ms  kbn-bb6-link.ip.twelve99.net [80.91.254.90]
 12   115 ms   115 ms   116 ms  sto-bb2-link.ip.twelve99.net [62.115.139.172]
 13   121 ms   123 ms   120 ms  hls-b4-link.ip.twelve99.net [62.115.123.203]
 14   130 ms   132 ms   129 ms  mts-ic-357601.ip.twelve99-cust.net [80.239.135.171]
 15   149 ms   147 ms   147 ms  fedor-cr04-eth-trunk9.spb.mts-internet.net [195.34.50.74]
 16   146 ms   147 ms   146 ms  mag9-cr02-be12.msk.mts-internet.net [195.34.53.13]
 17   146 ms   146 ms   146 ms  a433-cr06-eth-trunk15.msk.mts-internet.net [212.188.28.102]
 18   147 ms   151 ms   147 ms  a433-cr05-eth-trunk55.msk.mts-internet.net [212.188.42.40]
 19   147 ms   148 ms   146 ms  as25513.asbr.router [212.188.6.35]
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
SE client and server VPN are used
ping mgts.ru
Request timed out.
Request timed out.
Request timed out.
Request timed out.
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
tracert mgts.ru
  1     *      139 ms   140 ms  192.168.30.1
  2   138 ms   139 ms   141 ms  192.168.1.1
  3   139 ms   138 ms   138 ms  172.16.253.50
  4   141 ms   138 ms   140 ms  172.16.253.244
  5   139 ms   139 ms   138 ms  188.191.160.165
  6   140 ms   144 ms     *     100.105.103.106
  7   140 ms   140 ms   145 ms  178.178.110.201
  8   142 ms   141 ms   141 ms  83.169.204.65
  9   141 ms   140 ms   146 ms  83.169.204.184
 10   142 ms   141 ms   140 ms  m9-cr04-be95.msk.mts-internet.net [212.188.61.6]
 11     *      141 ms   142 ms  a433-cr06-eth-trunk4.msk.mts-internet.net [195.34.53.114]
 12   139 ms   141 ms   142 ms  a433-cr05-eth-trunk55.msk.mts-internet.net [212.188.42.40]
 13   141 ms   142 ms   158 ms  as25513.asbr.router [212.188.6.35]
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16   142 ms   144 ms   141 ms  94.29.127.190
 17   166 ms   142 ms   142 ms  94.29.127.189
 18     *        *        *     Request timed out.
 19   145 ms   141 ms   141 ms  62.112.96.34
SE client and VPN gateway are used
ping mgts.ru
Reply from 195.178.108.240: bytes=32 time=251ms TTL=242
Reply from 195.178.108.240: bytes=32 time=252ms TTL=242
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 251ms, Maximum = 252ms, Average = 251ms
tracert mgts.ru
  1   187 ms   186 ms   187 ms  10.211.254.254
  2   192 ms   187 ms   188 ms  192.168.1.1
  3   193 ms   190 ms   192 ms  100.103.0.1
  4   188 ms   189 ms   188 ms  10.144.8.1
  5   190 ms   191 ms   190 ms  82.142.130.198
  6   201 ms   200 ms   202 ms  pe02.Krasnoyarsk.gldn.net [79.104.247.43]
  7   207 ms   201 ms   201 ms  79.104.212.245
  8   254 ms   254 ms   253 ms  sem275-cr02-ae0.24.krsk.mts-internet.net [212.188.0.166]
  9   251 ms   253 ms   251 ms  bhm-cr04-eth-trunk9.nsk.mts-internet.net [212.188.2.1]
 10   250 ms   253 ms   249 ms  psshag-cr01-ae12.0.chel.mts-internet.net [195.34.50.153]
 11   252 ms   257 ms   251 ms  che-cr02-ae10.63.sam.mts-internet.net [212.188.42.129]
 12   252 ms   252 ms   250 ms  a433-cr06-eth-trunk13.msk.mts-internet.net [212.188.1.181]
 13   250 ms   269 ms   253 ms  a433-cr05-eth-trunk55.msk.mts-internet.net [212.188.42.40]
 14   251 ms   253 ms   250 ms  as25513.asbr.router [212.188.6.35]
 16     *        *        *     Request timed out.
 17   252 ms   251 ms   255 ms  94.29.127.190
 18   254 ms   257 ms   252 ms  94.29.127.189
 19     *        *        *     Request timed out.
 20   253 ms   250 ms   253 ms  62.112.96.34
 23   252 ms   251 ms   251 ms  195.178.108.240
Trace complete.
Post by solo » Tue Dec 30, 2025 7:25 am
For reference, the connection was configured using Azure. My friend was unable to set up port forwarding...
There it is... Azure - that's why you are blocked. Let me elaborate. Your VPN via JP Azure server massively increases network latency which can be easily "detected and blocked". Also your friend's CGNAT-induced latency does not help for sure. Read more about it:
First, establish a baseline latency for users with a known geographic region that are known not to be connected to a VPN. This can be done by measuring the latency between the client and a known server, such as a popular website or a server within the organization. By doing this, you can understand the typical latency range for non-VPN users in a specific location.
Second, continuously monitor the latency of users within your network. This can be done using network monitoring tools, which can analyze network traffic and measure latency between different nodes. Look for instances where the measured latency is significantly higher than the established baseline for a specific geographic region. This could indicate that a user is connected to a VPN, as VPNs generally add extra latency to network connections. To increase the accuracy of VPN detection, it's essential to correlate latency measurements with other data, such as IP addresses, geographical data, DNS requests or browser fingerprinting.
Measuring Latency to Detect VPNs
If you can do port forwarding at your location, this VPN could be "restructured" without Azure and with lower latency it may (might) then work for you.
assagai
Post by assagai » Tue Dec 30, 2025 6:41 pm
Thank you for the insight! I suspected Azure might be involved, but I wasn’t aware of the underlying mechanism.
We’ll attempt to set up port forwarding and test it again.
Post by solo » Wed Jan 07, 2026 2:07 pm
Well, how did it go? A reversed VPN without VPS gateway and with minimal latency is rather tricky to establish. Don't hesitate to ask for help if you need it.
assagai
Post by assagai » Wed Jan 07, 2026 9:17 pm
We are working on it :)
My friend is not capable of doing it by himself. He needs to be present at home and perform the necessary setup under my (mis)guidance. TeamViewer no longer works in Russia, whereas other remote desktop programs compatible with Windows 7 give poor picture resolution, so that I can hardly see anything on the screen. Given the time difference, his schedule, and technical hurdles, it is not an easy task.
My idea is to create a second, separate connection – without using Azure - to test both and verify the latency hypothesis.
Post by solo » Thu Jan 08, 2026 12:15 am
Please double-check viable port forwarding at your location first. Don't use NAT-T in the test, note https://www.vpnusers.com/viewtopic.php?f=7&t=69614
Your friend's setup stays the same except for adding a cascade to your SE server. This could be done with a script, no remote access is necessary.
About the hypothesis. Presumably you had opted for Azure because your DDNS address and NAT-T were unsuccessful. If unsure, re-try it and see what happens with a direct connection with decreased latency. Depending on ISPs, the tech may be operational in reverse as cascades can function with NAT-T and then port forwarding is not essential but only desired for reliability.
assagai
Post by assagai » Sat Mar 21, 2026 7:45 pm
I haven’t posted any updates because my diagnostic efforts have been largely unsuccessful. I don’t have sufficient knowledge or expertise to determine whether my ISP is blocking incoming ports, and there does not appear to be a straightforward way to verify this on a Windows 7 machine.
I also came across another site that does not open through VPN: https://lkfl2.nalog.ru/lkfl/. On a few occasions, through trial and error, I managed to find a public VPN Gate server that allowed access, but most do not. It is unclear whether these VPN Gate servers bypass Azure (and therefore evade detection by the latency test you described), or whether some other mechanism is responsible.
The lack of detailed logging in SoftEther is also unhelpful, as it provides only minimal entries with little actionable information.
In addition, I encountered a puzzling issue: a SoftEther client on a Windows 7 machine configured with Azure has stopped connecting to the server. Reinstallation and reconfiguration did not resolve the problem. Meanwhile, a SoftEther client on a Windows 11 machine, using identical settings, connects to the same server without any issues.
The log output is as follows:
2026-03-21 11:38:45.470 Connection processing for VPN Connection Setting "MS SSTP Azure" has started.
2026-03-21 11:38:45.470 VPN Connection Setting "MS SSTP Azure": Connection operation starting (attempt 1).
2026-03-21 11:38:50.514 VPN Connection Setting "MS SSTP Azure": The connection has either been disconnected or failed. Cause: Connection to the server failed. Please check the network connection and verify that the destination server address and port number are correct. (code 1)
Russia is continuing to tighten control over internet usage, affecting both incoming and outgoing connections. It appears that bypassing these restrictions is becoming increasingly difficult.
Post by solo » Wed Mar 25, 2026 12:04 am
According to the tracert log above, your ISP is unlikely to be blocking incoming ports. Here is a quick test:
  1. install SoftEther server (all defaults, no presets required)
  2. on your 192.168.1.1 router forward port TCP 443 to the PC with SoftEther server
  3. from a cell phone on mobile network (wifi off) browse your DDNS address https://vpnXXXXXXXXX.softether.net
What do you get?
assagai
Post by assagai » Mon Mar 30, 2026 2:23 am
What do you get?
I substituted XXX with an appropriate number
Chrome:
This site can’t be reached vpnXXXXXXXXX.softether.net refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
Firefox:
Unable to connect
An error occurred during a connection to vpnXXXXXXXXX.softether.net.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the web.
Pinging vpnXXXXXXXXX.softether.net works and correctly resolves to the provider’s IP https://www.whois.com/whois/188.191.167.82
Post by solo » Mon Mar 30, 2026 3:00 am
Hold on, this test was meant for your location, not your Russian friend's.
'If you can do port forwarding at your location, this VPN could be "restructured" without Azure and with lower latency' - the objective again.
assagai
Post by assagai » Sat Apr 04, 2026 10:37 pm
I may be missing something fundamental here—it’s difficult to follow the setup instructions without fully understanding how the system works.
My immediate objective is to access certain web pages from within Russia, where access is restricted from abroad.
I have installed the SoftEther VPN Server and attempted to configure it following the official guide https://www.softether.org/4-docs/1-manual/7/7.2. I am able to launch the VPN Server Manager and create a new virtual hub using the default settings, as described in the documentation. However, when I try to connect to this configuration from my local PC, I receive an “Access Denied” error.
As a result, I am unable to use the assigned address in the format VPNXXXXXXXXX.softether.net.
I have reinstalled the software several times, but the same error persists.
Post by solo » Sun Apr 05, 2026 1:54 am
Please review the three steps above viewtopic.php?p=104730#p104700
None of them demands to "connect to this configuration from my local PC". Just proceed exactly as advised.
assagai
Post by assagai » Sun Apr 12, 2026 6:08 pm
I had previously installed SoftEther VPN Server to familiarize myself with the setup and to help a friend with installation on his machine. As a result, when I installed it again, the process differed from a clean installation. In particular, I was initially unable to access the server properties to view the address in the format VPNXXXXXXXXX.softether.net.
After some trial and error with uninstalling and reinstalling, I was eventually able to obtain the current DDNS hostname in the format VPNXXXXXXXXX.softether.net. I then assigned a static IP address to the laptop and forwarded TCP port 443 to that address.
However, when I try to access the address from a device outside my local network, I receive the message: “This site can’t be reached. vpn527274468.softether.net took too long to respond.”
Given the complications arising from repeated installations, I am still not entirely confident that I followed the intended setup correctly.
I will be visiting a relative shortly who uses a different ISP, and I can attempt to test the connection there once more.
Post by solo » Sun Apr 12, 2026 11:31 pm
For reference, the expected response is like this https://vpn.packetix.net/
Ensure that you browse https://vpnXXXXXXXXX.softether.net where the inclusion of "https" is essential.
assagai
Post by assagai » Thu Apr 30, 2026 8:51 pm
I apologize for snail pace – I am constantly distracted by my relative’s health issues and jump back at the problem sporadically.
It did work this time. I’ve attached a screenshot from my friends phone
https was included for all of the attempts
Post by solo » Fri May 01, 2026 1:51 am
Excellent result, no worries about snail pace. Before we proceed with the VPN's restructure please ask your RU friend for a simple test.
  • add a user+password to your hub
  • ask your RU friend to cascade from his hub to your hub on the vpnXXXXXXXXX.softether.net address, port 443 and above user+pass
  • ...and check if the cascade's status is "online"
  • if it is "online", keep it going and re-check next day (stability test)
This is a necessary prerequisite as there are reports that RKN blocks some IP ranges and no VPN trick can work around it.
https://www.softether.org/4-docs/1-manu ... Connection
