Trying to set up VPN server on Windows 10 PC. I cannot create a local bridge because the VPN manager is reporting "no physical network adapters suitable for Local Bridge were found on the VPN server computer."
The PC definitely has a physical NIC - the Realtek Gaming GbE Family Controller that is built into the ASUS TUF Gaming X570-Plus mainboard. However, even when I edit the VPN server config to set ShowAllInterfaces to true, this one still doesn't show up.
Anybody know what's going on?
No suitable adapter for local bridge
Re: No suitable adapter for local bridge
Post as code the output of:
PS> Get-NetAdapter | Format-List -Property ifAlias,InterfaceDescription,PromiscuousMode
vpncmd localhost:port /server /password:*** /cmd BridgeDeviceList
NigelC
Thanks for your help solo.
I managed to resolve the issue.
For some reason, the SoftEther Lightweight Newtork Protocol was enabled on all adapters except the ethernet adapter. Once I enabled it I was able to use it to create a local bridge.
