I'm having issue with the softether Server VPN.
The cert expiry date is 2030.
There's no changes on the softether server VPN. But suddenly, cannot connect to the VPN.
I have check the settings 1 by 1, there's nothing change.
I have tried change the port from the softether client side, port 992, 443, but still cannot connect.
How to solve?
VPN Server and Client Issue
koskpz
Re: VPN Server and Client Issue
I will subscribe and follow the discussion. I also have a problem. The settings do not change. But sometimes error 1 occurs when connecting the client. It arises and disappears on its own. I can't figure out the reason.
Since you use NAT-T, VPN connections are intermittent, limited or none at all...
https://www.vpnusers.com/viewtopic.php?f=7&t=69441
https://www.vpnusers.com/viewtopic.php?f=7&t=69614
https://www.vpnusers.com/viewtopic.php?f=7&t=69804
Btw, to only "change the port from the softether client side" is absurd.
