Static Routing Table - 64 entires.
mshakurov
Post by mshakurov » Tue Jan 20, 2026 8:20 am
There is a "Static Routing Table" option in the SecureNAT settings. There are only 64 entries. Is there a way to transfer larger tables with more records to the client?
Re: Static Routing Table - 64 entires.
Post by solo » Tue Jan 20, 2026 1:08 pm
Sure, run an alternative DHCP server https://www.vpnusers.com/viewtopic.php? ... 671#p97671
