I would like to request the access logs.
subin
Post by subin » Sat Jan 31, 2026 12:36 pm
Hello, I am a user of SoftEther VPN.
I was informed that on November 23, 2025 at 23:43, a movie titled “捕風追影” was downloaded using a torrent program through my IP address. 😢
However, I do not know what this movie is, and I have no memory of downloading it.
I believe this may have happened because I was participating in a Gate Relay, and someone else may have used my IP address.
I would like to request the logs showing the usage of my IP address around November 23 at approximately 23:43.
Unfortunately, I deleted and reinstalled the program, so no log files remain on my system.
As a long-term user of SoftEther VPN, I sincerely ask for your help.
Thank you very much.
Re: I would like to request the access logs.
Post by solo » Sun Feb 01, 2026 12:19 am
subin
Post by subin » Sun Feb 01, 2026 4:04 am
Thank you for your response!! Unfortunately, I do not have access to past records.
I reinstalled the program on November. 27, so only logs from after that date remain, and all earlier data has been lost.😢😢😢
I need the logs to prove my innocence to the police...
RetroBat
Post by RetroBat » Fri Feb 06, 2026 2:40 pm
Try use Recuva or other recovery software on the log folder mentioned in a earlier reply. Second option is Windows Event viewer network/security logs. There you can maybe prove that the Gate Relay.exe initiated a connection to a torrent tracker IP?
