Please see the attached file. I am using SoftEther for a Remote Desktop Session host but I have found it could be causing performance issues by creating an instance for every user, when in fact it is only System that is required.
Is there a way to configure SoftEther to run as a single System service that provides the tunnel for the entire host, rather than spawning per-user processes? I want the system to handle the VPN at the OS level so that user sessions simply inherit the route without the overhead of individual client instances.
Any advice on "service-only" mode or Registry tweaks to prevent the UI/Client from auto-launching in RDSH sessions would be greatly appreciated.
vpnclient_x64.exe and vpncmgr_x64.exe create an instance for each user on Remote Desktop Session Host.
ClintonWestwood
Re: vpnclient_x64.exe and vpncmgr_x64.exe create an instance for each user on Remote Desktop Session Host.
Install it with "System Administrator authority" https://www.softether.org/4-docs/1-manu ... rvice_Mode
ClintonWestwood
Thanks. Isn't this for the server? It's the VPN Client that I have the issue with.solo wrote: ↑Tue Feb 10, 2026 9:15 amInstall it with "System Administrator authority" https://www.softether.org/4-docs/1-manu ... rvice_Mode
If they all connect to the same destination, then let the host connect there as admin, and then RDP users simply directly enter the remote LAN's address.
