Gate error
LoreSmith
Gate error
Hello! Until yesterday, I could connect to almost all the servers on the list without any problems, but now I can only connect to this server (lueders1.opengw.net) with ip (209.159.244.182), and the others are not working. Please help me, I really need to connect to Japan!
Re: Gate error
All JP servers work fine. Your government is blocking VPNs.
Try UDP.
Try UDP.
bsfgp
Re: Gate error
Same issue here, i cannot even refresh the server list. I can only connect to one single weak server from Vietnam.
DSUser123
Re: Gate error
for me, it still connects to some opengw.net servers, but not all of them are working and they eventually time out. Using the UDP protocol. I'm from Russia.
taliban
HELP PLEASE
the VPN stopped working and I couldn't connect through the TCP protocol, which immediately displayed error 2. When I tried to connect through the UDP protocol (which I had always used in the past), it displayed error 1. Previously, everything worked perfectly, but I don't know what happened now.
Sincerely,
Puzzled
Sincerely,
Puzzled
LoreSmith
Re: Gate error
Listen, we know that our government blocks this, and believe me, I want to say a lot of bad words about them, but I'm even afraid to write anything about it here... We are like birds in a cage, and the cage gets smaller every day... I just want to ask for help. If you know anything about this or are somehow connected to the developers, believe me, we would be really, really grateful to you for this help.
Re: Gate error
Read carefully and absorb it viewtopic.php?f=7&t=69901#p104153In the context of SoftEther's VPN Gate project, all counter-detection features are completely useless...
Next, if you can't get Starlink, setup a server in EU and then tunnel to it on SoftEther's protocol viewtopic.php?t=69366
oscar
Re: Gate error
solo wrote: ↑Wed Mar 04, 2026 11:57 pmRead carefully and absorb it viewtopic.php?f=7&t=69901#p104153In the context of SoftEther's VPN Gate project, all counter-detection features are completely useless...
Counter-detection feature are NOT actually completely useless,UNLESS:
1.SoftEther project start opening a new API/implement a new ceder module within the client called "advanced Anti-DPI active probing & advanced firewall proof protocol refactor"module,if so , the SE-VPN protocol itself needed to be rebuilt the entire softether project wide
2.Currently,any clients implements the v2ray / vmess / shadowrocket etc & so on used the local http proxy function a lot,but due to the networking API limits ios & android devices have , such programs cannot run in background and accept the original SoftEther Protocol to directly connect over it [ via the virtual hub like softether does] in such client creates like 198.18.0.1 for some clients called clash , and 127.0.0.1 for vmess protocol in v2ray.
The module actually do very good about DPI firewall blocking bypass,however it's totally just wrapping softether protocol as an overlay underlying protocol,which still works under a standard TCP/IP model [ It's simpler than OSI model] , but however developers have difficulties dealing with the API architecture between the OS,the clients which implements vmess shadowsocks etc & etc , and cascading softether protocol over it
3.Actually if just cascading 2 protocols within 1 softether module stacks which sends/ receive the underlying SE-VPN protocol it's simple, you can use https://github.com/fatedier/frp to make SE-VPN data flows over it,but the key point in my post in this thread is,such change must be done SoftEther project wide,not just some random users commitng their own modified versions of the softether client & server,such copies of the program will only works for such users not solving the current problem "SE-VPN protocol being flagged by Advanced DPI systems",to address such problems a refactor of the softether protocol is must involved,but will dnobori and softether authors in vpnusers.com actually accpet such suggestions? It would be great if they actually do.
oscar
Re: Gate error
All counter detection will actually works if softether project implements a new protocol refactor and add features to the 10 years old SE-VPN protocol which don't changed even after 10+ years after this project is released to the public
Re: Gate error
Oscar, your ideas are useful only for a secret, private VPN server. Here we are discussing VPN Gate public servers. Note that the operators of GFW, RKN, IRG, etc. don't care about your censorship circumvention methods, nor need to bother with DPI to detect SoftEther's traffic - they simply log IPs from www.vpngate.net and block them.
As for FRP and your incessant begging to implement its support, keep in mind that your free public reverse proxy IPs are just as easily discovered. You could run your own secret reverse proxy on a paid server somewhere, but then you might as well setup a secret SoftEther tunnel right now, as it is, no need to "rebuilt the entire softether project wide" - lol.
oscar
Re: Gate error
Because i've successfully did this,and cascaded softether to another TCP layer 4 within FRP,so as you see on this forum i've already tried many uncommon cascading ways including but not limited change the API,cascading to another virtual 198.18.0.1 eth0 card,or transit the TCP to 127.0.0.1:1000 in vmess v2ray client,such cascading and modified versions of softether use cases worked,but such details on this forum vpnusers.com are barely talked about[on how to do it in code],but trying out and actually found it's working on both code & OSI model is very fantasticsolo wrote: ↑Thu Mar 05, 2026 12:43 pmOscar, your ideas are useful only for a secret, private VPN server. Here we are discussing VPN Gate public servers. Note that the operators of GFW, RKN, IRG, etc. don't care about your censorship circumvention methods, nor need to bother with DPI to detect SoftEther's traffic - they simply log IPs from www.vpngate.net and block them.
oscar
Re: Gate error
Also if you cascade SoftEther inside another TCP in v2ray shadowsocks,then the actual use of vpngate.net is useless,OSI model tell us all the truth,what i'm trying very hard to do now is on ONLY software based logic within inside the operating system TCP/IP model,not the physical OSI model like a router or a wifi in a typical home or school office.solo wrote: ↑Thu Mar 05, 2026 12:43 pmOscar, your ideas are useful only for a secret, private VPN server. Here we are discussing VPN Gate public servers. Note that the operators of GFW, RKN, IRG, etc. don't care about your censorship circumvention methods, nor need to bother with DPI to detect SoftEther's traffic - they simply log IPs from www.vpngate.net and block them.
You can also say that Layer 3 in such countries don't actually works the way it supposed to,nor vpngate.net will,but however being able to interact and change the software logic is fantastic enough
oscar
Re: Gate error
rebuilt the entire softether project wide is for bypass DPI from within that country mainly,you can call it "the SoftEther special edition for DPI firewalled countries" , this is a must if you need softether actually working from inside that country,not just cascading from another shadowsockssolo wrote: ↑Thu Mar 05, 2026 12:43 pmOscar, your ideas are useful only for a secret, private VPN server. Here we are discussing VPN Gate public servers. Note that the operators of GFW, RKN, IRG, etc. don't care about your censorship circumvention methods, nor need to bother with DPI to detect SoftEther's traffic - they simply log IPs from www.vpngate.net and block them.
nikto_and_nobody
Cannot connect to servers from Russia
Hello everyone! I live in Russia, and as far as I understood, our government blocks every public IP located outside. I don't know how it works. I'm a social science student, I'm trying to find a job outside to fly away and get an access to technologies, but now I cannot even access LinkedIn... May I ask somebody to explain me or suggest a right algorithm to set up my private server somewhere in Asia or EU and join it exclusevly? The government would not ban it, unless it public right? I have just looked up several services like "the.hosting" with servers for 5 euros (vCore x1, 1 GB RAM ECC, 25 GB NVMe): will it work for me, or I should not even spend time and money because it will be eventually banned?
I am sorry to have no knowledge in these technologies. I am trying to have Gemini explained me them, but I still cannot comprehend it. If anyone has any suggestions or at least a link to an insturctions - I would really appreciate it!
Re: Cannot connect to servers from Russia
Read this thread. Don't create new topics on the same subject over and over again.nikto_and_nobody wrote: ↑Sun Apr 12, 2026 6:42 pmIf anyone has any suggestions or at least a link to an insturctions - I would really appreciate it!
In short:
https://www.softether.org/4-docs/2-howto
How to make a Tunnel
Cheap VPS example
diggeler
Re: Gate error
Indeed, they blocked both individual volunteer computers and UDP servers. It doesn't allow connections via UDP, but allows UDP connections via TUNNEL. I had 15 or more volunteer connections, and all but three were shut down. Now only one works, a never-ending beast. But I don't use it. Despite the appearance of complete chaos, there are still loopholes.
diggeler
Re: Gate error
Seriously, forgive me for butting in, but block protection already exists and is used, and I just think, wish, and pray that there will be more unblocked servers, good and diverse ones. Technically, it already works today and can be scaled. I use it myself. I think it's designed specifically to protect connections from blocking. This is a public channel, so I won't go into details.
diggeler
Re: Gate error
Tested on May 10th, some previously non-working connections were resurrected, a good sign, others, a few, are pinged, but do not connect
Moscow
Moscow
Re: Gate error
@diggeler, thank you for the updates. How's Tor there? Your intermittent VPN problems could be related to ISP's erratic implementation of censorship control. Your friend on a different ISP may not have identical issues or vice-versa. When one of you finds a working VPN Gate server, you could share it locally in RU, no need for any VPS - viewtopic.php?p=104847#p104835
diggeler
Re: Gate error
21 мay Today at approximately 11:00 AM Moscow time, ping to many VPNGATE 443/tcp servers disappeared. I checked with other VPN channels running in the VPNGATE system, as well as with European VPNs. There is no ping or connection. Why did this happen?
at least 20 servers lost ping
At first I thought this was a new attack by RKN, but after I couldn't find a ping from alternative sources, I began to doubt that it would have been difficult for RKN to pull this off right away.
diggeler
Re: Gate error
I currently have 4 working VPNGATE volunteer connections, not all are blocked, but the ones that are working are SSTP
diggeler
Re: Gate error
May 21, 21:30 MSK: The ping to the 20 servers—which had previously dropped out—has now been restored! The connection is working.
diggeler
Re: Gate error
Today, June 7, a new escalation in Roskomnadzor’s blocking measures was detected, and a number of unpleasant incidents occurred—the defenses were breached. However, the cause was quickly identified: the 9.9.9.9 DNS service. It has either been compromised, bought off, or is simply riddled with holes and is leaking my identity to Roskomnadzor. Do not use it!
diggeler
Re: Gate error
Hello! Right now, almost all SSTP connections from Russia are dead, except for a few; it’s unknown why those few still work, though the reason the others don't is clear. The SecureNAT protocol is disabled—an AI recommended that—but it hadn't helped previously anyway; it was likely intended for UDP traffic, but that doesn't work.
It is completely unclear what distinguishes the few SSTP servers that *do* work. Furthermore, up until a point in August, about 40 SSL servers were functional—I tested them all, and they successfully connected me (I’m ignoring the ones that never connected in the first place). So, 40 were working, but then they started failing—1, 2, 5, 10—and now 29 servers won't connect. We assume this is due to blocking, yet the remaining 14 still work, raising the question again: what makes them different? How do I set them up? By creating a manual connection in the client—not by selecting from a server list, but by entering each one manually and selecting TCP only; that’s how all servers were configured after March 2026. Now 29 are blocked, and the crackdown appears to be continuing. I’ve checked, and all the so-called "non-working" servers actually function if I "jump-start" them using another VPN connection—like SoftEther or similar. The failure manifests as an inability to connect, with no ping response, or perhaps DNS blocking. Connections "jump-started" this way used to pass the test, but now they fail the test too. I’ve read about SSL, SSL2, and SSL3, but it’s unclear what can be done here. I use the encrypted 1.1.1.1 DNS provided by Windows 11 and manually enter the same address in the virtual adapter's DNS field. Do you have any other recommendations? I’d like to restore at least one of the non-working SSL server connections. I do have a backup option (FPTN). We certainly didn't expect this level of problems, but it is what it is.
Re: Gate error
Please check both ICMP and TCP ping mode viewtopic.php?t=68421#p105045
