how to connect to VPN Server vpn1.softether.net ?
oscar
Post by oscar » Fri Mar 06, 2026 2:40 pm
how to connect to VPN Server vpn1.softether.net ? I don't know which virtual hub should used to create the VPN Connection.
Also can you don't delete my post? @solo , the vpn1.softether.net server is found at https://www.softether.org/@api/deki/fil ... server.jpg
THIS IS NOT A SECRET IP ADDRESS AT ALL,right? It's on a publicly open web page https://www.softether.org/ deleting my post isn't right
Also,what's the reason for my post asking about vpn1.softether.net server access is deleted?
Re: how to connect to VPN Server vpn1.softether.net ?
Post by solo » Fri Mar 06, 2026 9:12 pm
Your post is here viewtopic.php?t=70046
C'mon oscar, pull yourself together.
oscar
Post by oscar » Sat Mar 07, 2026 12:38 am
I think this is a VPN server with NAT enabled,and vpn1.softether.net seems not blocked by any DPI-enabled countries
Because the vpn1.softether.net hostname is rarely used? or just because i need to request the username & password to access the virtual HUBs on it?
