SoftEther server throughput
Milo
Post by Milo » Fri Apr 24, 2026 6:45 am
we are running SoftEther VPN Server 4.44.9807 in VMware virtual machine with Linux Debian 13. We have a single virtual hub named VPN. This hub is bridged directly into eth1 interface. eth1 interface is in dedicated VLAN and this VLAN is routed by our core switch/router, so not by server itself. Our majority clients are Windows clients with SSTP. And because of an extensive CPU usage and high load of virtual machine we limited downlink/uplink in virtual hub admin options to 24/24 Mbps per client. It works quite good.
But now, thanks to infrastructure innovation, we have a spare old hardware server with Intel Xeon CPUs E5-2680 v2 @ 2.80GHz, 40 cores total, 250 GB DDR3 RAM. And I'm testing the throughput on it. Network setting on server is following:
- 2x 10 Gb trunk interfaces into the core router
- above it 1x bond0 interface with fast LACP
- above it vlan1 with public IP vlan.example.com and vlan2 in dedicated VLAN in our network
The 1st attempt was the same setup as with VMware virtual machine, but without bitrate limits. VPN hub bridged directly into vlan2@bond0 interface. It worked but throughput of SSTP was bad. Upload ~30 Mbps, download ~4 Mbps. So I googled and found https://serverfault.com/questions/83264 ... ad-is-high
The 2nd attempt is much better. VPN hub is bridged into tap0 interface and I've created bridge br0 with vlan2@bond0 + tap0. The throughput of SSTP shot up immediately to 50/50 Mbps. When I use SoftEther VPN Client, I can hit throughput 180/180 Mbps (when connected via 200/200 Mbps provider).
And I have a so many questions:
a) Why is the download so poor when the virtual hub is bridged directly into vlan2@bond0 interface? Are there any kernel/interface options which can improve it?
b) Are there generally any kernel/interface/server parameters that are recommended to be tuned for better performance?
c) Is there a really ~triple SSTP protocol overload which causes such lower throughput? Or it's due to the old server CPU?
Thank you very much for reading this far :)
Re: SoftEther server throughput
Post by solo » Fri Apr 24, 2026 8:30 am
Try the developer edition viewtopic.php?f=7&t=68529#p100007
Milo
Post by Milo » Fri Apr 24, 2026 10:45 am
Compiled on last commit (cf559617b1845e0892e51f41d0c67e7382f02c4c) and tested. Unfortunately got the same result as with stable version.
- hub bridged directly to vlan2@bond0 - 5/40 Mbps (SSTP)
- hub bridged to vlan2@bond0 via tap0 - 50/50 Mbps (SSTP)
The 50/50 speed via SSTP seems quite constant. I've tested it from local desktop and connection speed to tested server is 1000/1000 Mbps without VPN.
Post by solo » Fri Apr 24, 2026 11:15 am
I suspect that on bare metal you'd still need offloading disabled
viewtopic.php?f=7&t=68690
Milo
Post by Milo » Fri Apr 24, 2026 12:54 pm
ethtool -K enp3s0f0 gso off gro off tso off
ethtool -K enp3s0f1 gso off gro off tso off
does the magic and direct bridge between virtual hub and vlan2 interface works with a same speed as via tap interface.
But SSTP speed remains 50/50 Mbps.
Post by solo » Fri Apr 24, 2026 1:49 pm
Check CPU usage and the 40-core load distribution, try irqbalance service, if unresolved report it here https://github.com/SoftEtherVPN/SoftEtherVPN/issues
Milo
Post by Milo » Mon Apr 27, 2026 7:39 am
A single client loads 4-5 cores to 10-50 % (by guess from htop) when performing speed test. I've installed and run the irqbalance service and checked it is running. SSTP speed remains 50/50 Mbps.
This state I should report as issue on GitHub?
Post by solo » Mon Apr 27, 2026 9:40 am
Yes, also search there for SSTP/throughput, eg. https://github.com/SoftEtherVPN/SoftEth ... ssues/2000
But first check SSTP throughput to a Windows server.
Next, connect your client to a VPN Gate server in native and SSTP modes - is there a big difference like your 180 vs 50 Mbps?
