A detailed question about routing domain within a os @cedar
oscar
How do i create a local bridge with local bridge attached to a local VPN Client VPN adapter NIC card?
http://www.packetix.net/en/vpn/help/site.aspx
The machine is connected to a VPN Server and working fine.
But how do i bridge this local VPN Client NIC card into the softether server local bridge to my own virtual HUB?
In dropdown menu in local bridge do not shows up any NIC adapters that starts with VPN Client.
So,inside the OS of my machine,if i do not want to touch the local Ethernet[public internet facing]default routing table,how can i transparently router the VPN Client NIC adapter into another adapter in microsoft loopback adapter? I know there's a way to create a windows bridge simply with 2 clicks but however the VPN server is DHCP forcefully used and doing so will fail to get an ip address.
So i need other ways to transparently local bridge mirror the VPN Client NIC to another microsoft loopback adapter right within windows and don't use the built in windows network MAC bridge?
oscar
Re: How do i create a local bridge with local bridge attached to a local VPN Client VPN adapter NIC card?
Or
netsh interface portproxy add v4tov4 listenport=5556 listenaddress=0.0.0.0 connectport=4000 connectaddress=10.236.12.85
might do the job?
might do the job?
oscar
How to let windows local bridge a non promiscuous mode compatible NIC to my own virtual HUB?
As a special usage method, it is going to be possible to bridge connection by layer 2 between VPN Client computer Virtual Network Adapter and existing physical network adapter connected to the computer. As for, the bridge function of the operating system is going to be use for this. With SoftEther 1.0, bridging between Virtual Hub and physical network adapter has been often accomplished by this method. With SoftEther VPN, however, because bridging could be accomplished easier and faster by local bridge connection function of VPN Server or VPN Bridge, this method ceased to be used frequently.
I have NICs in windows,but they do not support promiscuous mode at all,how to add a local bridge to the virtual HUB?
oscar
DHCP boardcast to softether public servers are blocked when VPN Client adapter put in windows bridge
The VPN cannot get a DHCP IP address from the VPN Server,because the VPN Client adapter is in a device called windows bridge,how to solve this problem? The policy is forcefully get ip address from VPN virtual DHCP and manaul IP address will discarded
oscar
A last call for softether:People found ultimate way to bypass policy limit on router bridge mode
Punishing people by blocking they username in this board WILL NOT WORK AT ALL , even if you patch such bug in software people just finds another BUG to archive unblocking and jailbreaking limits
people now will start bridging www.vpngate.net into http://www.packetix.net/jp/vpn/help/1.Install softether VPN Server inside that 34.96.100.11 machine in system mode
2.Install https://r1ch.net/projects/forcebindip
3.https://download.vpngate.jp/common/cd.a ... 164560.zip
4.Config the VPN Client IPv4 properties with interface metric with a very large number larger than the local NIC to internet 34.96.100.11 for example 9999,in this way,even if the routing default gateway is modified by softether client,the os will still not use this route as a primary default gateway route[important]
5.Connect 219.100.37.58:443,in softether VPN Client,but keep No adjustments of routing table box unchecked.
because interface metric is sky high the windows os do not change default routes and gateway to default internet gateway at all,34.96.100.11 will remains accessiable by ssh or rdp
6.change the cmd working directory to forcebindip64.exe install directory ForceBindIP64.exe 10.236.25.51 C:\SE\So\vpnserver.exe /usermode [10.236.25.51] is the vpn client internal ip address
7.at this point,any clients using VPNazure.net services into my 34.96.100.11 with virtual HUB [bridge] with vpnmymachine.vpnazure.net will get ip address 219.100.37.58,note:they're not using any ip address in my 34.96.100.11 machine at all but still gets an 219.100.37.58,in this case the actual thing is ForceBindIP64.exe did the job,so it's still bypass the softether limits.
8.And yes,the connection is working very fine,no need to modify anything,just forcefully to make softether server to use 10.236.25.51 not 10.0.0.1,so it's not hard,and you can see my VPN Server program is forcefully using the 10.236.25.51 interface to make any outgoing connections to any softether servers [including 130.158.6.51],so in such case 219.100.37.58 is still forcefully used [you can check whether it is with https://systeminformer.sourceforge.io/]
Look here , the VPN Server is forcefully running on local NIC 10.236.25.51,there's no reason for my server not to have a public ip 219.100.37.58
So i'm actually changing the softether server in windows just allowed to use 10.236.25.51 only not to use 10.0.0.3 public internet NIC at all
How easy is this? Only 1 exe will do the job!
Look here,client ip address[source host]is not my machine local 10.0.0.1 public internet NAT NIC any more,instead it's the VPN Client NIC responsible for creating the connection!
and yes,all policy is bypassed now just with 2 clicks in windows machine,no high tech savvy things included at all,just forcefully make softether use 10.236.25.51 don't allow it to use 10.0.0.3 at all,this is all what's needed!
SID-VPN-6322 is a VPN Session created by the 219.100.37.58 session,not my machine,this is what i'm trying hard to trick softether to do:Local Mac address spoofing,and it works safe and sound,everyone's happy now!
The SID-VPN-6322 is able to populate any mac ip table entries it wants and mac spoofing is so confortable to archive,and by the way your advices are very helpful for me,still,thank you,i should find more way to trick softether into working in such local spoofing modes
oscar
Re: A last call for softether:People found ultimate way to bypass policy limit on router bridge mode
Trust it or not? @solo
No worries as long as you post your "successful reversals" only on this Idle Talk Board.
oscar
This thread is for plan A:Use local bridge with ICS mini virtual NAT in windowssolo wrote: ↑Mon Apr 27, 2026 10:32 amNo worries as long as you post your "successful reversals" only on this Idle Talk Board.
There's also plan B
// Examine a number of MAC addresses that are registered in this current session
for (i = 0;i < num_pp;i++)
MAC_TABLE_ENTRY *e = pp;
if (e->Session == s)
num_mac_for_me++;
Free(pp);
limited_count = 0xffffffff;
if (s->Policy->NoBridge)
limited_count = MIN(limited_count, MAC_MIN_LIMIT_COUNT);
if (s->Policy->MaxMac != 0)
limited_count = MIN(limited_count, s->Policy->MaxMac);
limited_count = MAX(limited_count, MAC_MIN_LIMIT_COUNT);
if (num_mac_for_me >= limited_count)
// Number of MAC addresses that are registered already exceeds the upper limit
char mac_str[64];
if (s != NULL)
MacToStr(mac_str, sizeof(mac_str), packet->MacAddressSrc);
if (no_heavy == false)
HLog(hub, "LH_BRIDGE_LIMIT", s->Name, mac_str, num_mac_for_me, limited_count);
else
HLog(hub, "LH_MAC_LIMIT", s->Name, mac_str, num_mac_for_me, limited_count);
goto DISCARD_PACKET; // Drop the packet
There's a thing called code analysis,people will eventually only modify softether's side without touching their local OS system
When that will happen?On which day? One day you'll find the answer yourself @solo
oscar
num_mac_for_me++; -> DELETE
//limited_count = MIN(limited_count, MAC_MIN_LIMIT_COUNT); is commented out
//limited_count = MIN(limited_count, s->Policy->MaxMac);is commented out
goto DISCARD_PACKET; // This line is dropped
oscar
Do forget that commented out lines do not runs at all,and if a code block or function or void() is omitted entirely,such function disaapears,and don't overthink softether is prone at anti code reversing and any software will potentially vulnerable to external modification,no bridge router policy can ALWAYS BYPASSED with very little efforts and with relatively low tech involved.solo wrote: ↑Mon Apr 27, 2026 10:32 amNo worries as long as you post your "successful reversals" only on this Idle Talk Board.
oscar
Let's suppose an OS,with the following configs in NIC[network interface cards,for short NIC]:
Let's suppose it's running windows.
NIC A:This is A NIC which have the following configs:
IP = 10.0.0.3 , netmask = 255.255.255.0 , gateway = 10.0.0.1 , DNS = 8.8.8.8 [suppose it got an public IP address 1.1.1.1] , and from internet , allowed users can use 1.1.1.1 IP to SSH RDP admin access via NIC A,with default routing table [target] 0.0.0.0 [netmask] 0.0.0.0 [interface] 10.0.0.1
NIC B:This is A VPN NIC which connected to a VPN corp network
IP = 192.168.30.103 , netmask = 255.255.255.0 , gateway = 192.168.30.1 , DNS = 8.8.8.8 [suppose it got an public IP address 2.2.2.2] , and from internet , users can access http frp via 2.2.2.2
The routing table ON NIC B as follows:
[target] 0.0.0.0 [netmask] 0.0.0.0 [interface] 192.168.30.1
The NIC A is local bridge with the softether server virtual HUB "MYHUB",the secureNAT on this hub is the same as NIC A.
The problem is,if i want hosts within the 10.0.0.0/24 network segment [ in this case users under HUB "MYHUB"] to directly like under the network segment 192.168.0.0/24 [ in this case users under HUB "MYHUB" uses the network resources in 192.168.30.103 or 192.168.0.0/24
Without starting ICS or RRAS NAT service on NIC B,is it possible to archive such networking architecture that meets my requirements?
Or did route add 10.0.0.0/24 in windows or static route push under "MYHUB" secureNAT configs will do it?
Or must i use virtual NAT in windows in some way? @cedar
Re: A detailed question about routing domain within a os @cedar
It is difficult to achieve this purely through configuration.
This is because the WAN side of SecureNAT is effectively fixed to the network that has the default gateway, due to hardcoded logic in the VPN Server.
Conversely, this implies that by hacking this logic, it may be possible to force the WAN side of the virtual NAT to use a specific virtual NIC.
However, in order for the machine to continue functioning as a VPN server, the default gateway must remain assigned to the physical NIC. Therefore, it is not possible to assign the default gateway to the virtual NIC.
It is also important that the virtual NIC does not have its own IP stack, and that SecureNAT operates in kernel-mode NAT.
https://ja.softether.org/4-docs/3-kb/VPNFAQ036
oscar
cedar wrote: ↑Fri May 01, 2026 1:46 pmIt is difficult to achieve this purely through configuration.
Perhaps in one day [which day? no one knows] softether finally allows the server program to manually prompts the user to choose which NIC on the host machine to use,because https://github.com/MisterCalvin/forcebindip-gui already did this,and having such function is just a piece of cake.
Finally this problem is fixed with https://github.com/MisterCalvin/forcebi ... i/releases
It's totally possible without ANY difficulties,you can try it today right away,it'll use the NIC you select in APP to start vpnserver.exe
Also,it's possible to run 2 vpnserver.exe simultaneously inside the same windows operating system,create 2 windows users and vpnserver.exe /usermode will work,just change the vpn_config.json tcp listening ports not to conflict to each other like tcp 443 in VPNserverA.exe,then tcp 444 in VPNserverB.exe
This means in a same windows machine,vpnserver can acts as 2 different servicing parts,one using IP address 10.236.25.6 while the other uses 10.0.0.3
Also there's many 3rd party apps & plugins already in https://github.com/pkts-rs/tappers
For linux https://medium.com/@amazingandyyy/intro ... 4e0c02d084
Also,we're doing circles since public1.softether.com do not support IPv6 public access at all,nor vpngate.net servers have a public ipv6 address,and in IPv4 a single plugin exe is enough for the needs,however in the future if only IPv6 access is allowed we absolutely need another approach.
About vpnserver.config files posted here
And this is another working approach in my another online forum
sc create sevpnserver2 binPath= "\"C:\SoftEther_Server2\vpnserver.exe\" /service" DisplayName= "SoftEther VPN Server 2" start= auto
You need to actually rename them BOTH to
vpn_server.config
with such file appears independently in 2 paths like
C:\Users\Administrator\Desktop\A\Server
C:\Users\Administrator\Desktop\B\Server
If you start vpnserver.exe without having vpn_server.config exists from path from the beginning
It'll create a default vpn_server.config with factory defaults [without users custom config lines]
# Software Configuration File
# You can edit this file when the program is not working.
declare root
uint ConfigRevision 13
declare DDnsClient
bool Disabled false
byte Key eTYZ5OyXI5Lf4j/CqWYjun9nPbc=
string LocalHostname iZuac37u5ts2ykZ
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare IPsec
bool EtherIP_IPsec true
string IPsec_Secret vpn
string L2TP_DefaultHub VPNA
bool L2TP_IPsec true
bool L2TP_Raw true
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
bool EnableSoftEtherKernelModeDriver true
bool ShowAllInterfaces true
declare LocalBridge0
string DeviceName Red$20Hat$20(ID=1916811767)
bool FullBroadcastMode false
string HubName VPNA
bool MonitorMode false
bool NoPromiscuousMode false
declare root
declare DDnsClient
bool Disabled false
uint ProxyPort 0
uint ProxyType 0
declare IPsec
bool L2TP_Raw true
declare Listener0
bool Enabled true
uint Port 1443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
string HubName VPNA
oscar
さらに,vpnserver.exeが使用しているネットワークアダプタを注意深く確認してください。
VPN Serverに対応する内部IPアドレス10.236.0.0/24である。
デフォルトでは、192.168.0.0/24 または 0.0.0.0/0 のいずれかで動作します。
10.236.0.0/24 で動作する場合、そのパブリック IP アドレスは間違いなく 10.236.0.0/24 のインターフェースに対応するものとなり
192.168.0.0/24 や 0.0.0.0/0 のような無関係なネットワークセグメントに対応するパブリック IP アドレスにはなりません。
この投稿に関する最大の論争点は、デフォルトで 192.168.0.0/24 や 0.0.0.0/0 インターフェースで動作するため、様々な奇妙なトラフィック分割やルーティング戦略が発生する可能性があることです。
コマンド「ipconfig /all」を実行すると
これは、VPNサーバーが現在カーネルモードのセキュアNAT、またはユーザーモードのSecure NATで動作しているためです。
「route print」コマンドでは、明らかにWindows ICSのインターネット共有ネットワークセグメントである192.168.137.1は表示されません。Windowsの内部ルーティングテーブルが一切変更されていないことは確実です。
ただし、VPNクライアントアダプタのMACアドレステーブル 5E-40-2F-0B-69-5A は、VPNサーバーのMACアドレステーブルビューアには表示されません。VPN Client Adapter - VPN
5E-40-2F-0B-69-5A
10.236.233.148(primary)
255.255.0.0
GW = 10.236.254.254
DNS = 8.8.8.8
oscar
さらに、セッションの詳細を確認すると、これがルーター/ブリッジモードのセッションであることが明確に示され、ローカルIPアドレスは確かに10.236.0.0/24ネットワークセグメントに属しています。
これはVPNクライアント自身のNATとVPNサーバー自身のSecureNATスタックを完全に活用しており、Windows上のルーティングテーブルやゲートウェイは一切変更されていません。
ForceBindIP is useless
"People found ultimate way to bypass policy limit on router bridge mode"
No, it is not ultimate but convoluted and relies on ancient ForceBindIP which still works here only because you are using user mode.
viewtopic.php?t=69924#p104411
Here is the simplest way to bypass the policy:
Do not quote everything, remember?
viewtopic.php?t=70058#p104668
- in a VM networked in NAT mode install SE or VPN Gate client, default setup
- in the same VM install SE server, default setup
- on the hub set DisableKernelModeSecureNAT = 1
- enable SecureNAT, default setup
oscar
Re: ForceBindIP is useless
So,the old problem remains unsolved here:on the hub set DisableKernelModeSecureNAT = 1
Answer softether vpnserver.exe 2 simple questions:
There's 2 NIC in windows
NIC A IP=192.168.1.1 metric = 1
NIC B IP = 10.236.1.1 metric = 9999
Question 1.On which NIC IP address interface vpnserver.exe will listen on?
Question 2.How did a user choose which NIC interface for vpnserver.exe to use when using ForceBindIP is forbidden and not allowed for a japanese styled punishment?
oscar
The VM cannot tolerate the modification of the default gateway and default 0.0.0.0/0 route ,which means as soon as an 219.100.37.58 is connected,any SSH RDP access towards 192.168.1.1 on the VM will break because VPN Client will omit the 192.168.1.1 gateway making the VM totally unrouteable from it's default interface gateway.in a VM networked in NAT mode install SE or VPN Gate client, default setup
Also note that if you SSH RDP towards 219.100.37.58:[local VM SSH RDP port] won't work at all because 219.100.37.58 is TCP/443 to public only and it won't ever run a TCP/IP server nor a listener on 219.100.37.58 itself,this is basic networking knowledge,just connected to it won't port mapped to it,nor it can rdp ssh over 219.100.37.58,if 219.100.37.58 allows internal LAN local routing,then it already becomes an free LAN-Local linked allowed server and 130.158.6.51 won't exists at all
The 130.158.6.51 allows all kinds of communications with just 1 exception:It do not have a publicly NATable interface with the function to access the public internet,so you cannot use 130.158.6.51 as a public NAT ip address to access youtube,you had to buy a hosted VPS or server to make your server cascade connect to 130.158.6.51 to make it actually work
For how to use 130.158.6.51 anyone can finds out at http://www.packetix.net/en/vpn/help/
No need to change NIC metrics to solve anything. The VM is NAT-networked and an external SE client gets priority routing automatically.
Switch to a different translation service because your gibberish posts are nauseating.
oscar
You need to change NIC metrics forcefully,take a closer look at download/file.php?id=3658&mode=view
The source IP address where vpnserver.exe make a TCP Connection originating from 10.236.0.0/24 , which means local 192.168.1.1 are not responsible for dealing the NAT function at all,but again,who decides whether 10.236.0.0/24 or 192.168.0.0/24 NIC interface will used?
Of course it's a parameter controlled by the NIC metrics,this can be forcefully and manaully changed at each time you use the VPN Client NIC card,where it's not a secretly changed metric value but you can forcefully and clearly manaully set it to a specific value,and the result are just like plain math,let's supposed it's like x + y = 3 in math,the X = ? & Y = ? is not just guessing but a clearly defined value you forcefully make windows to follow that exactly
https://learn.microsoft.com/en-us/troub ... pv4-routes
https://learn.microsoft.com/en-us/windo ... ace-metric
oscar
Leave NIC metrics alone, in this context DisableKernelModeSecureNAT decides that, read...
https://ja.softether.org/4-docs/3-kb/VPNFAQ036 - in other words, in User-mode SecureNAT it simply follows OS' routing table, which is precisely what we want.User-mode SecureNAT is the first implemented mode, which converts TCP and UDP access from within the virtual hub to the outside into a stream, and then converts it to communication using the TCP/IP stack provided by the host OS.
viewtopic.php?p=104841#p104835 - did you think that the method was a contrived, theoretical concept only? It works exactly as described, check logs from the VM:
netstat -anb
Active Connections
Proto Local Address Foreign Address State
TCP 0.0.0.0:5500 0.0.0.0:0 LISTENING
[vpnserver.exe]
Active Connections
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING
TCP 0.0.0.0:443 0.0.0.0:0 LISTENING
TCP 0.0.0.0:992 0.0.0.0:0 LISTENING
TCP 0.0.0.0:1194 0.0.0.0:0 LISTENING
TCP 0.0.0.0:5555 0.0.0.0:0 LISTENING
TCP 0.0.0.0:28921 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49156 0.0.0.0:0 LISTENING
TCP 10.0.2.15:139 0.0.0.0:0 LISTENING
TCP 10.0.2.15:5500 10.0.2.2:9758 ESTABLISHED //ext. SE client's IP is NAT-ed!
TCP 10.0.2.15:5500 10.0.2.2:9761 ESTABLISHED //ext. SE client's IP is NAT-ed!
TCP 10.0.2.15:58216 60.71.4.56:1393 ESTABLISHED //int. SE client to vpn176878445.opengw.net
Active Routes:
0.0.0.0 0.0.0.0 10.211.254.254 10.211.1.20 2
1.1.1.1 255.255.255.255 10.0.2.2 10.0.2.15 10
10.0.2.0 255.255.255.0 On-link 10.0.2.15 266 //ext. SE clients are on VM NAT
10.0.2.15 255.255.255.255 On-link 10.0.2.15 266
10.0.2.255 255.255.255.255 On-link 10.0.2.15 266
10.211.0.0 255.255.0.0 On-link 10.211.1.20 257
10.211.1.20 255.255.255.255 On-link 10.211.1.20 257
10.211.255.255 255.255.255.255 On-link 10.211.1.20 257
60.71.4.56 255.255.255.255 10.0.2.2 10.0.2.15 10 //int. SE client to vpn176878445.opengw.net
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
130.158.6.105 255.255.255.255 10.0.2.2 10.0.2.15 10 //University of Tsukuba
tracert -h 5 8.8.8.8
Tracing route to dns.google [8.8.8.8] over a maximum of 5 hops:
1 226 ms 226 ms 227 ms public-gw.vpngate.net [10.211.254.254]
2 228 ms 227 ms 227 ms 192.168.3.1
3 251 ms 245 ms 245 ms softbank221111179174.bbtec.net [221.111.179.174]
4 245 ms 244 ms 245 ms softbank221111179173.bbtec.net [221.111.179.173]
5 245 ms 245 ms 273 ms 10.9.203.14
External SE client's logs...
Tracing route to 8.8.8.8 over a maximum of 5 hops
1 * * * Request timed out.
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 279 ms 288 ms 268 ms softbank221111179173.bbtec.net [221.111.179.173]
//JP VPNGATE vpn176878445.opengw.net
curl whatismyip.akamai.com
60.71.4.56
oscar
[/quote]
[/quote]
There's always a case where a user must forcefully to listen on 10.236.0.0/24 interface only,also with listening on 192.168.0.0/24 forcefully disabled and disallowed for some reason,some easy reasons are:
1.they use vpngate.net for purely it's purpose:mask the originating source IP address without revealing the connection source ip address to the public NAT side,they start a NAT service for NATing other's servers but keep in mind they do not want IP source address to be revealed.
2.they forcefully make hosts behinds the NAT use only vpngate's source ip address for some annonymous reasons,because as it's a vpngate server any local NAT or proxy firewall cannot tap on the local device or if it must,they either cuts of the connection to that ip address entirely[this is what gfw,iran,north korea does] or blacklist the DDNS hostname of the server [ the chinese GFW does]
3.after putting the main network under the VPN Gate public ip address routing domain,what ever 3rd party server a user wish to connect[or in this case,let's supposed user is already connected to 219.100.37.58,and he wants to connect to another L2TP Server using the 219.100.37.58 interface then ForceBindIP.exe is a must,what this means is when the local user device connects to a second VPN L2TP Server what the local network usually blocks will using 219.100.37.58 keeping L2TP or other VPN conections unblocked
[/quote]
So you finally agree that there is a much simpler method for the policy bypass but insist that some usage scenarios or edge cases demand NIC metric adjustments and resorting to the old, abandoned, unsupported, limited or rather dysfunctional ForceBindIP.
Let's dispel this notion immediately as there is a better way to navigate among NICs. All you have to do is DisableKernelModeSecureNAT and "route add..." to pick any network interface(s) you desire - no need for altered metrics nor ForceBindIP.
oscar
[/quote]
"route add..." to pick any network interface(s) you desire.
[/quote]
route add is only available for device which logged in with admin / root / su privileges accounts.
for example,iphone ios is also easily to do this.
but by default https://www.apple.com/ios do not have root access to the OS at all,it's not impossible but the OS disallows.
windows and linux [in some special cases some version of android have full root access so we only need to root our androids and it'll work] are always run in root / admin mode,you can't feel anything is blocked.
For ios,it's possible to route https://apps.apple.com/us/app/sstp-connect/id1543667909 traffic into mobile wifi hotspot,a root and https://www.tetherme.net/ [but untested on ios 18.7.6] needed
Route add isn't enough,you cannot easily make windows to start a L2TP or IPSec/SSTP session directly using the 10.236.0.0/24 interface,however if you have another device on network it may work,so forcebindip can replace that needing to having a second network device to archive "L2TP IPSec / SSTP Session over 10.236.0.0/24 interface"
[/quote]
Sure, but ~~~LOL~~~ what a bunch of nonsense in the context of SoftEther, SecureNAT, NIC metric and ForceBindIP application. Has it not occurred to you that:
- ForceBindIP does not run on iOS
- NIC metric is not applicable on iOS
- you need admin/root to adjust NIC metric on Windows/Linux
- etc. etc.
oscar
How to directly Layer 2 Forcefully start another VPN Server on other-person hosted VPN Servers
How to directly Layer 2 Forcefully start another VPN Server on other-person hosted VPN Servers[Force a layer 2 connection into they's boardcast domain in softether]
1.Start a vpnserver.exe LOCALLY on your machine,but in this case a normal NAT/just a normal VPS is better for relaying traffic and spoofing IP Address.
2.Create a virtual HUB,but in this HUB,delete ALL NAT DHCP Cascading connection session,leave it a empty HUB ONLY.
3.declare LocalBridgeList [ShowAllInterfaces True is forcefully needed,and you're always needed to import the .config back to softether server and restart it]
4.It's better in usermode,this is easy,
declare Option
bool DisableIpRawModeSecureNAT true
bool DisableKernelModeSecureNAT true
5.Use https://r1ch.net/projects/forcebindip or https://github.com/MisterCalvin/forcebindip-gui if needed
6.Create a VPN Client locally in the same machine,but config the VPN NIC metric to a sky high value to tell windows don't use it as it's not a primary NIC as possible
>powershell
Set-NetIPInterface -InterfaceIndex (VPN NIC IF number) -InterfaceMetric 9999
7.Create a LOCALBRIDGE device between the HUB in softether VPN Server & the VPN NIC,click yes if it says it's uncommon to do such bridging
8.Just create a VPN Connection to YOUR OWN Server running this softether VPN Server,by default many VPNGATE servers on vpngate.net is forcefully DHCP NAT Enabled,so when making connection to your own LOCAL-VPN-NIC bridged server,set the VPN Client on your device in DHCP mode(static ip/dns configs = empty non exist),actually because it's layer 2 bridged your clients to your own LOCAL-VPN_NIC bridged server will eventually get a DHCP IP Address from the layer 2 bridge VPN adapter it's locally running,there's nearly 0 possibilities that a compatibility problem may occur,this method is for ALL common places,as such,all limits are bypassed with your own personally set up softether server
declare Option
>powershell
oscar
Re: How to directly Layer 2 Forcefully start another VPN Server on other-person hosted VPN Servers
And,yes,this forcefully uses layer 2 bridging directly from inside the VPN NIC Card in softether client,perfect if you checked "no adjustment of routing tables" and this is your own controlled server
[yawn]
...the same boring stuff yet again.
