Ubuntu v24 Route all traffic via vpn
tutti
Post by tutti » Wed May 06, 2026 10:22 am
I tried to use softether on my linux ubuntu < noob on linux still learning.
I can connect via vpncmd no problem
I changed /proc/sys/net/ipv4/ip_forward to 1
dhclient vpn_vpn_se
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
0.0.0.0         192.168.10.1    0.0.0.0         UG        0 0          0 wlp1s0
10.211.0.0      0.0.0.0         255.255.0.0     U         0 0          0 vpn_vpn_se
192.168.10.0    0.0.0.0         255.255.255.0   U         0 0          0 wlp1s0
Routing is only via local ip
after sudo ip route add 10.211.0.0 via 192.168.0.1 and or 10.211.1.6 via 192.168.10.1 vpn ip
and ip route del default via 192.168.10.1
10.211.0.0      192.168.10.1    255.255.0.0     UG        0 0          0 wlp1s0
10.211.1.6      192.168.10.1    255.255.255.255 UGH       0 0          0 wlp1s0
no internet access and vpn get disconnected after I remove the default 192.168.10.1 gateway
Re: Ubuntu v24 Route all traffic via vpn
Post by solo » Wed May 06, 2026 10:31 am
tutti
Post by tutti » Wed May 06, 2026 11:21 am
solo wrote: ↑
viewtopic.php?f=7&t=68335&p=99223#p99223
connect and note the server's address
- ip route add [server address] via [default GW]
- ip route del default
- dhclient vpn_vpn
so are we talking "server adress" the ip from the VPN tunnel or the IP I got from the VPN tunnel.
42.117.xxx.xxx   192.168.10.1    255.255.255.255 UGH       0 0          0 wlp1s0
anyway I did post the code for the IP that the vpn server gave me and no the IP from the VPN Server both getting disconnected when I "Ip route del default"
Post by solo » Wed May 06, 2026 11:26 am
tutti
Post by tutti » Wed May 06, 2026 12:08 pm
solo wrote: ↑
viewtopic.php?f=7&t=68894&p=101124#p101124
tcp 0 649 192.168.10.107:56166 42.117.xxx.xxx:1454 ESTABLISHED -
Kernel IP routing table
sudo ip route add 42.117.186.34 via 192.168.10.1
and whole connection is down
