Kipperkahn wrote:
> It is not a provider issue as i have tried a Telus and Bell Sim in the
> toughbook.
> Anyone have any ideas.
Actually it may be a provider issue - common to many cellular providers - and that is that they NAT your cellular modem on a private (non-routable) network. So you may browse network no problem , but trying to reach back to a private network address is challenging and you can't forward ports easily (or at all)
I have been playing with this and using SecureNAT works on a Verizon router I have, but the only way I can connect to the Server behind a Verizon cell connection is using the Windows Softether client. This works pretty well, but because of the private IP I am not able to make Android OpenVPN client or built in Windows client work.
Any other ideas from anybody else? I would love to get better functionality for this cellular case also :)
Thanks
VPN connection NOT working on 4G (works on Wifi)
triwaves
Re: VPN connection NOT working on 4G (works on Wifi)
Does the VPN server run on the toughbook?
