Hi all, i'm new in this, i'm using the VPN connection and works fine, at least the first try of connection, but if i disconnect and connect again i get this error
Error (Error Code 2):
Protocol error occurred. Error was returned from the destination server.
I'm using win 7 with ver-4.22 (9634).
To get start working again i must restart the computer, disconect internet don't works, closing other apps or reset my wireless device or reinstall the driver either.
(I don't know where is the log)
Edit:
Checking using UDP works.
Thx.
Error 2 when i try reconnect
Re: Error 2 when i try reconnect
Could you try to restart the router?
