In some cases connecttions with UDP could linkup while TCP were fail. However if I saved the settings (IP, ports...) into a new connection then reconnect it, the new one will try to link w/ TCP only. I'm not sure how to indicate UDP only within the connection setting page.
Thanks a lot!
How to export setting of connection with UDP ?
Batman
Re: How to export setting of connection with UDP ?
Attached 2 screens for this question. One is tcp/udp selection page when connecting, another is part of connection setting page, where only tcp is acceptable.
Does someone know how to resolve this problem? Many thanks!
