I have
1)vpnserver on debian
2)vpnclient on Ubuntu, which connect to office local network 192.168.0.0/24
3)vpnclient on debian in my home which connected 2nd interface to home local network 192.168.160.0/24
I want to have access to office network. For it i use softether vpn server with virtual interfaces from creator with virtual network 192.168.171.0/24
In sum
1)office comp has 2 addresses, 192.168.0.66 local and 192.168.171.30 virtual
2)home comp has 2 addresses, 192.168.160.1 local and 192.168.171.1 virtual
I setup routing, and all work, but i can ping only 3 last addresses.
You can see it in pictures.
I have ping to 192.168.0.1,192.168.0.4,192.168.0.48 but to 192.168.0.218 i don't have ping.
If i delete any entry it will work, and i have ping to 0.218 again. How solve it, why i can use only 3 ext for vpn addresses.
Forwarding Not work
prizes
Forwarding Not work
prizes
Re: Forwarding Not work
I solved the problem, after change vpnclient on vpbbridge, but if you use router like mikrotik and other, it will be imposible.
I hope that creator will fix this bug with sessions on vpnclients.
