I'm trying to setup my SoftEther VPN server to be able to accept OpenVPN connections from clients.
The problem is, even with the
auth-user-passerror message.You must define CA file (--ca) or CA path (--capath)
Is there any way to setup SoftEther so that it accepts OpenVPN connections without certificates and keys?
If that's not possible, does anyone have a tutorial/guide on how to create these certificates and keys? I tried using the XCA Windows app but I get all sorts of TLS failure error messages with that.
