Extremely hard to use the VPN Gate portal – am I doing it wrong?
Sergeek
Post by Sergeek » Sun Oct 19, 2025 1:22 am
Greetings! Firstly, I want to salute the people behind the VPN Gate project. Such a humanitarian digital resource is invaluable in modern times. That's why I ask you not to interpret this topic as a complaint or rant. I appreciate what your group is doing. Yet I'm at a loss and don't know what to do.
I'm from Russia, and as you surely know, internet censorship runs rampant here. So a year ago I stumbled upon VPN Gate and started to use it through the OpenVPN Connect utility. From the very beginning I had problems. I could never connect to profiles provided by Mr. Daiyuu Nobori and still can't. In fact, only a handful of profiles did work for me. And when they did, they were on for a couple of days. In time, things got worse. VPN Gate portal and its original mirror stopped working (currently using the "saitama" one). Fewer and fewer profiles were functional, and a couple of days of work became a day. Recently, I can't even squeeze a single day out of a profile. Just an hour ago, I downloaded a working one after filtering through almost the entirety of the website... Only for it to break within minutes.
But Russians are one of the largest pieces of traffic on this portal. Obviously most of the user base has no problems with it. Then it means that I'm doing something wrong. I'm not a tech-savvy person, so I don't understand what. Please, can anyone advise me?
Re: Extremely hard to use the VPN Gate portal – am I doing it wrong?
Post by solo » Sun Oct 19, 2025 2:15 am
Yeah OpenVPN client reconnects every 10 seconds
Use SoftEther client instead of OpenVPN.
Sergeek
Post by Sergeek » Tue Oct 21, 2025 6:01 am
Thank you very much! I used SoftEther with VPNGate plugin from the download section of the site and it works way better! Are there any similar apps for Android OS? I know about the built-in client, but maybe there is a specialised 3rd party software solution?
Post by solo » Tue Oct 21, 2025 7:38 am
Sergeek
Post by Sergeek » Wed Oct 22, 2025 11:08 am
On Android 15+ get https://github.com/kittoku/Open-SSTP-Client
Unfortunately, I'm on Android 12. So even though I was able to install this app, it never works with unexpected error.
In fact, I tried using L2TP/IPsec guide from the site, but built-in vpn client never connects no matter which server address I use.
Post by solo » Wed Oct 22, 2025 1:20 pm
OK for me on Android 12.
