"Double" VPN with Softether?
sunxpert
Post by sunxpert » Mon Jan 23, 2017 9:24 am
Hi all,
I want to make a "double" VPN with Softether. The goal is to have entry node IP different from exit node IP. I have 2 VPS machines running. I have installed softeher on one of them and it works fine as a regular VPN. What do I do next? Does Cascading between VPN HUB and VPN Bridge solves my problem?
Another option I have in mind is setting up SOCKS server(shadowsocks?) on 2nd VPS and routing all traffic from 1st VPS to socks5 on 2nd, but I'm not sure how to accomplish that.
Please advice.
Regards.
moatazelmasry
Re: "Double" VPN with Softether?
Post by moatazelmasry » Mon Jan 23, 2017 12:00 pm
May I ask what are you trying to achieve exactly?
sunxpert
Post by sunxpert » Mon Jan 23, 2017 12:23 pm
Multihop VPN connection. Where the entry point(where I connect) is different from exit node(my public IP).
So, like this
Client -> VPN1(IP1) ->VPN2(IP2) ->Internet
Hope that makes it clear.
sunxpert
Post by sunxpert » Mon Jan 23, 2017 1:50 pm
So far the solution I found is the following:
1. VPS1 and VPS2 both have SoftEther VPNs Servers running with SecureNAT(DHCP&NAT-T) enabled on both systems.
2. VPS2-->Cascade Connection-->VPS1.
3. VPS2 SecureNAT default gateway is set to VPS1's default gateway.
This way my entry node is VPS2 which is routed to VPS1 via default gateway setting.
Is is the proper way of setting things up?:) Doubt it.
Let me know what you think.
mask
Post by mask » Wed Aug 07, 2019 10:51 am
Did you succeed with this configuration?
sky59
Post by sky59 » Wed Aug 07, 2019 6:57 pm
So, like this
Where is the server for vpn?! What are vpn1 vpn2? Where do they connect? To which servers?
rain520com
Post by rain520com » Wed Jan 22, 2020 9:56 am
My solution is:
1. VPS1 and VPS2 both have SoftEther VPNs Servers running with SecureNAT (DHCP & NAT-T) enabled on both systems.
2.Host Machine + Virtual Machine (VMware), the Internet mode of Virtual Machine is NAT mode.
3.Configure the VPN client in the virtual machine. Next, i first run the VPS1'S VPN on the host machine (my main operating system), and then i run the VPS2'S VPN client in the virtual machine.
Problems arise:
I set up VPS1 ’s VPN client on the host machine, and the network of the host and the virtual machine is normal. However, when I set up VPS2's VPN client in the virtual machine, I can only log in to the client of social software. I cannot access the webpage and Google cannot open it.
Only using VPS2's VPN client or VPS1's VPN client in the virtual machine, everything is normal.
